Tc-33D/TC-40D with 4 in 1 bucket
   / Tc-33D/TC-40D with 4 in 1 bucket #1
jag123
I am a newbe, need advise on tractor size. I am leaning
to the TC-40 because of additional HP & Grunt, and 4 cy.
I need something with some grunt...........
Located in northern Ca. on 7 AC. in the Santa Cruz Mt.'s near
Los Gatos.
The ground is very hilly & hard, and the property is very tight.
Will be using the tractor for loading, clean up, clearing up
slides & brush, and some grading.
Also need advise on where to buy. North Carolina seems to
have the best prices, California is 4 to 5 k higher.
Any advise would be great.
Thanks Bill
   / Tc-33D/TC-40D with 4 in 1 bucket #2
jag, You should compare tractors within their own classes. The 33 is a class II, the 40 is a class III. Find the class that best fills your needs then choose between the tractors in that size range. I love my TC-33, but it ain't no class III ! Extra power is like 4 wheel drive, ya don't need it till ya NEED it !
   / Tc-33D/TC-40D with 4 in 1 bucket #3
I have a TC40D with a 4n1 and love it. If it is really tight I would suggest that you drive a Supersteer and see how it feels. I really like mine too. Get your 4n1 plumbed electric over hydraulic with a Fassee valve - nice little switch on the joystick to operate the clam. Best of luck.
Larry
Thanks for the reply Larry.
Fassee Valve, I belive thats the same as a one touch kit,
is it not.
Should be ording next week, after i'am sure I have all
the options decided on.
Bill
   / Tc-33D/TC-40D with 4 in 1 bucket #5
Bill,
Do be aware that most 4n1 buckets weigh quite a bit more than a standard bucket, and that will reduce your lift capacity. One reason to consider the larger sized machine.
L
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
Pallet of Attachments (A52377)
Pallet of...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
