TC 30 Four wheel drive system
   / TC 30 Four wheel drive system #11
i can't explain it like some of the other guys did , but i will say that 4wd on a tractor is most ammazing, the amt of extra traction and workability is beyond compare.
   / TC 30 Four wheel drive system #12
Frank_f15 really did the best job of explaining 4 wheel drive on compact tractors.
The reality is that differential locks and all that stuff are technical things that a mechanic understands. . .
BUT in terms of using a tractor in the real world, I will take a 4 wheel drive tractor into places that I could not take a Jeep Cherokee into. Actually the Cherokee probably could go there, but the tractor will come back out and the Cherokee will have to get pulled out.
I get amazed almost every time I take a tractor into a tight, slippery space and get it back out.
   / TC 30 Four wheel drive system #13
</font><font color="blue" class="small">( I'm not sure how big a tractor you have to go to, to also get a locking front differential.
)</font>
TNS and TND's with the electro hydraulic differential lock have locking front and rear differentials. To lock the differential with the electro hydraulic differential lock all you have to do is flip a rocker switch on the cab column. In one mode stays engaged until not needed. In another mode stays locked. Does make steering hard, but it seems there is still some differential action left.
Andy
   / TC 30 Four wheel drive system #14
I agree with Bird's explanations. My Boomer does not have a locking front differential and I'm pretty sure it's not available, but the rear has a foot pedal to lock it. If the tractor is weighted down good it gets a lot of traction and will usually stall the tractor or trip the hydrostatic drive relief valve before spinning the tires.
I disagree that it will always go places that a 4X4 truck or Jeep will not go. In some cases yes, but not always. In deep mud or snow, my 4X4 pickup, 4X4 Suburban, and my 4X4 Jeep will do better because I can get more speed to start with and keep the wheels spinning faster. I can't get the RPM's up enough sometimes with the tractor.
My understanding of why it's called Front Wheel Assist instead of Four Wheel Drive is because the front tires are smaller than the rear tires. To me, the biggest advantage of a 4WD tractor is when backing up a hill. The weight shifts to the front tires and a 2WD will spin out and not make it up the hill, where a 4WD will keep going. A 4WD is also much safer going down a hill, since the front tires provide braking and help keep the tractor going straight down instead of sideways. A 2WD tractor can be dangerous going down a hill because only the rear tires provide braking and it's easy to start skidding sideways.
   / TC 30 Four wheel drive system #15
<font color="#FF641A"> I know that most tractors only have a rear differential lock, however, the Kioti Dk65C has front lock also. I've never used one, but have heard from others who say it has really come in handy. 4 wheel drive (not front wheel assist) for me every time! John
   / TC 30 Four wheel drive system #16
Mosey, I probably shouold have been a little more clear in what I wrote. I can take my tractor onto soft ground in the trees where a jeep would not even fit, and I can get the tractor out. I can also take my tractor into tight spaces that a jeep would fit into but should not go, and I can get the tractor out. In terms of sheer deep mud performance, I would agree that a 4x4 is a better choice. In practical terms of what I use a tractor for, I am amazed that I have gotten the tractor out of some places I have got it into.
   / TC 30 Four wheel drive system #17
In my experience, I have not come across a 4wd tractor, that gets better traction, than a 2wd tractor. I am not saying that it doesn't, but I will explain my findings with the 2. Most all 4wd trucks, ATVs, and tractors have open, or limited slip differentials, with possibly the opition of a manual differential lever, or lock. This can be a knob, lever, switch, or button. It is only intended to be used temporarily, and to be taken out. It does cause the vehicle to want to drive straight, and steering can be difficult when the lock is engaged. Limited Slip differentials are necessary for most all vehicles, not just 4x4's. There are other systems, like AWD, that offer added traction for 4 wheeled vehicles. 4wd drive makes a difference with pickup trucks, jeeps, and atv's, but tractors are somewhat different. Tractors tend to be heavy, and where the rear tires is designed to obtain traction, hence the word "tractor". Tractor basically represents traction, as that is what tractors where designed to do, get traction.The original design of the tractor, with the large rear tires for traction, vs the small front tires for steering wasn't intended for 4wd traction. About 70-75% of the tractors weight is placed over the rear wheels, and about 25-30% of the tractors weight is placed over the front wheels. When a tractor is equiped with front wheel assist, those percentages have to change to get the appropriate amount of traction. The point, that the front tire of the tractor is smaller, does factor in, that it isn't like a pickup truck, which has 4 equal tire sizes, provided basically equal 4 wheel traction. On a properly ballast tractor that is 4wd, the percentage of the tractor weight is suppose to be like 45% rear, and 55% front. The thing with buying a 4wd tractor is, the process of ballasting it. You can use liquid ballast in the tires, wheel weights, and front weights. You can also use a weight box on the back, but that depends on you. Adding aditional weight could contribute to quicker mechanical component wear on the machine, though some manufactures compensate for this in the design itself. You would need to take a tractor to some kind of place to weigh it, to see how much weight is placed over each axle to ballast it properly.
   / TC 30 Four wheel drive system #18
ShannonCole888, in my experience with a NH 1920 w/ FEL & BH there is an enormous difference with having the front axle engaged or disengaged. When filling the loader bucket, with over 1000 lbs of backhoe as ballast, there is a significant difference in traction.
I have never done typical farming uses ie: a land plow, discs, or any other ground engaging implements, so I can't speak to the traction issue there. Bill C
   / TC 30 Four wheel drive system #19
I can say that with our L3830 (4x4 loaded rear tires, nothing on the front) pulling a 3 bottom plow, it spins the rear tires slightly when in 2wd but does not spin in 4wd.
Not really, if you look at the same model tractor in 2wd vs 4wd, there is no real difference in axle weights
A 4wd tractor has differen gearing for the front vs rear tires, so they cover the same amount of ground (rather than one spinning faster or slower)
Most CUT owners add weight to the front or rear to keep the tires on the ground when doing loader work or when using a heavy 3pt implement.
Aaron Z
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2015 KIA Cadenza (A50324)
2015 KIA Cadenza...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
