frank_f15
Super Member, Rest in Peace
i can't explain it like some of the other guys did , but i will say that 4wd on a tractor is most ammazing, the amt of extra traction and workability is beyond compare.
I can say that with our L3830 (4x4 loaded rear tires, nothing on the front) pulling a 3 bottom plow, it spins the rear tires slightly when in 2wd but does not spin in 4wd.In my experience, I have not come across a 4wd tractor, that gets better traction, than a 2wd tractor. I am not saying that it doesn't, but I will explain my findings with the 2.
Not really, if you look at the same model tractor in 2wd vs 4wd, there is no real difference in axle weightsThe original design of the tractor, with the large rear tires for traction, vs the small front tires for steering wasn't intended for 4wd traction. About 70-75% of the tractors weight is placed over the rear wheels, and about 25-30% of the tractors weight is placed over the front wheels. When a tractor is equiped with front wheel assist, those percentages have to change to get the appropriate amount of traction.
A 4wd tractor has differen gearing for the front vs rear tires, so they cover the same amount of ground (rather than one spinning faster or slower)The point, that the front tire of the tractor is smaller, does factor in, that it isn't like a pickup truck, which has 4 equal tire sizes, provided basically equal 4 wheel traction.
Most CUT owners add weight to the front or rear to keep the tires on the ground when doing loader work or when using a heavy 3pt implement.On a properly ballast tractor that is 4wd, the percentage of the tractor weight is suppose to be like 45% rear, and 55% front. The thing with buying a 4wd tractor is, the process of ballasting it. You can use liquid ballast in the tires, wheel weights, and front weights. You can also use a weight box on the back, but that depends on you.
