TC 29D arrived today
/ TC 29D arrived today #1
bher
Lancaster, PA
NH TC 29D
I got my TC 29D today. Already got in about 1.5 hours. I am having a great time and the tractor is everything and more than I expected so far. I tried to take off the plastic rear PTO cover. It would not budge. Am I doing something stupid? Do I just need to be more violent?
/ TC 29D arrived today #2
Congratulations on your new tractor. Sorry but don't know what to say on your pto cover. Goodluck and have fun /w3tcompact/icons/smile.gif
Darin
/ TC 29D arrived today #3
Well, so your plastic PTO cover won't budge...hmmm.... Might be cross-threaded since it is plastic. It should unscrew by turning it counterclockwise. If you can't do it with your hands, you might try a wrench, but I don't know how much pressure it will take. If I had to break it to get it off, I'd sure be asking my dealer for a replacement if I intended to ever put it back on. Good luck and enjoy your tractor, but remember to be careful. /w3tcompact/icons/smile.gif
JimI
/ TC 29D arrived today #4
As JimI said, it might be cross-threaded; mine is difficult to take off also. The threads are slightly deformed. I like to keep mine on because I don't use the PTO that often. Does anybody know of any metal replacement covers?
Chris
I was thinking about getting a pipe wrench on it. I could not quite yet bring myself to take the wrench to the clean shiny tractor. I will give the dealer a call. As always, thank all of you guys.
/ TC 29D arrived today #6
I'm not familar with your PTO plastic cover, so excuse my ignorance, but most I've seen just slips on the PTO tractor spline like a giant prophylactic...
I never seen one that screws on a spline...how?
/ TC 29D arrived today #7
<font color=blue>I never seen one that screws on a spline...how?</font color=blue>
The New Holland Compacts have a ring cast into the housing around the PTO shaft. About 3" I.D. on my TC33D if I recall. The inside of the ring is threaded, the outside of the PTO cover has a matching thread. The cover doesn't even make contact with the PTO shaft.
John Mc
/ TC 29D arrived today #8
Thank you John...
I'll get a chance and look at one on the lot.
On the utility sized units, they just slip on...
/ TC 29D arrived today #9
A pair of channel locks should take it off, if it does break, get a new one under warrenty at your dealer.
/ TC 29D arrived today #11
John,
I'm not familiar with the covers on the JD units but think that the cover on the NH units sounds different. The NH cover attaches to the PTO housing, not the PTO shaft. It not only keeps the shaft clean but also prevents any clothing contact with the shaft. This could be considered a safety plus as the PTO could be engaged yet the cover is not turning, of course we would never forget and leave a PTO engaged without an implement attached.../w3tcompact/icons/crazy.gif
DaveV
/ TC 29D arrived today #12
John Deere hinged PTO shield
Dave,
This is what JD uses as a "shield", but I thought they are talking about a "plastic" slip-on cover that goes over the spline... /w3tcompact/icons/crazy.gif
/ TC 29D arrived today #13
Re: PTO cover
The NH PTO cover is hard gray plastic. Looks almost like a cap to go on the end of some PVC pipe. Makes no contact with the spline. Mine has a somewhat squared-off end to allow gripping with a wrench (though I've never needed it). Fortunately, it fits in the miniscule tool box that came with the tractor.
/ TC 29D arrived today #14
John Miller,
Yes and yes. The talk was about a plastic cover (thread on, not slip) that is in addition to the hinged shield around the PTO area. Don't have a digital camera but might be able to borrow one from my brother this weekend and post a pic (unless someone here beats me to it) of the NH PTO area and PTO shaft cover. The NH website is pretty useless when it comes to pics of the "business end" of the tractor.
DaveV
/ TC 29D arrived today #15
<font color=blue>...The talk was about a plastic cover (thread on, not slip) & ...</font color=blue>
Dave,
You have to remember most of the time "my brain" is engaged in utility tractor mode.../w3tcompact/icons/smile.gif
Just about everyone I know, usually has an implement hooked on the rear of their tractor including PTO driveshaft most of the time... so "we" don't have a need for a PTO plastic cover... because it's in use... /w3tcompact/icons/blush.gif
So in a way, I just found it somewhat humorous of the concern over a "PTO slip cover"... /w3tcompact/icons/laugh.gif
I got it off. The dealer said wrench it and if it breaks he will give me a new one. It came off with a pipe wrench and some effort. The threads seem fine and it went back on and off OK. The tractor is a blast. If only I could find more time to use it. Thanks again.
/ TC 29D arrived today #17
I know we have beat this PTO subject so thin it's "threadbare", but here is a definitive photo of the NH plastic PTO cover on my TC45D. On my old Jubilee (Ford NAA) the PTO cover was essentially the same, but made of metal. The Ferguson To-20 I grew up operating was also metal and threaded. When I installed an overrun clutch (ratchet) on my Jubilee, the PTO cover wouldn't fit, so it is in my garage taking up shelf space. Just for your info and anyone else who might be curious, here's the photo./w3tcompact/icons/smile.gif
JimI<P ID="edit"><FONT SIZE=-1>Edited by jinman on 11/17/01 07:44 AM (server time).</FONT></P>
/ TC 29D arrived today #18
Re: Your photo, noted change in 45D
Looking at your photo reminded me of a difference I noticed on my new TC45D and yours. The drawbar bracket has been changed to a new style. (looks cast vs fabricated from flat stock) The PTO pump for my Woods 9000 hoe would not hook up and lock like it did on my old TC40D. The bracket has been redesigned for reasons I do not know. I guess I'll call Woods and see if they have a replacement bracket for the pump. Anyone know why the change? My guess is cost only.
/ TC 29D arrived today #19
Interesting difference...hmmm? I think I prefer the fabricated just because I have seen so many broken pieces which were cast. However, it just might be my unsubstantiated prejudice here. But different geometry making the Woods pump not fit is pretty serious. Can you post a picture? I wonder if this is a "limited" run or a permanent change./w3tcompact/icons/crazy.gif
JimI
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
