TBN questions
   / TBN questions #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
Something seems to have changed when I navigate the TBN forums. First of all, the Windows phishing filter is constantly working when I am moving around the forums greatly slowing things down. Secondly, after I view a picture and return to the thread, I am sent back to the first post instead of the post that contained the picture causing me to have to scroll back down to the post where the picture is located. Is there anything I can do to alleviate these problems. Maybe I need to change settings or something. Hopefully or moderator or someone else can set me straight.
   / TBN questions #2
Your second problem started when TBN did a major upgrade quite a while ago...it has been discussed a lot. The best work-around for it is to right-click on the picture and select "open in new tab (or window)"
Can't help with problem #1
   / TBN questions #3
The reason you are taken back to a different place on the page is because you viewed a thread that jumped you to a new post. For example, if the title bar has a # sign followed by a number at the end of it (#86902 for example) that means when you click back, you will be taken to that post regardless of where you were before.
It may seem that not all threads you click on will behave this way, because if you go to page two of a thread and then click an attachment link, you will be taken back to the proper place on the page.
As for the Windows phishing filter... I don't know much about that but we do utilize third party scripts and codes to serve advertising and that may be why your filter is slowing things down.
   / TBN questions #4
While in Internet Explorer, Click on "Tools" in the tool bar at the top of the page and then select "Internet Options". A new window will open with tabs across the top. Select the "Advanced" tab on the far right. Scroll down to the "Security" category (yellow colored lock icon). In the security section you should see some Phishing Filter options. Select "Turn off automatic website checking". Then select "Apply" then "OK". The window should close, and your done.
Joe
   / TBN questions #5
Possibly off topic here but I love GIJOE's signature line!!--especially the last part...
The original point and click interface was a Colt.
Only two defining forces have ever offered to die for you... the AMERICAN SOLDIER and JESUS CHRIST. One died for your freedom; the other for your soul
Joe
City of Buckhannon - 2014 Ford Fusion SE (A52384)
City of Buckhannon...
SAGE AIR COMPRESSOR W/ 100 GAL FUEL TANK (A52472)
SAGE AIR...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
