Tapping into my hydraulics
/ Tapping into my hydraulics #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
Under my seat is this block...... marked "in" and "out". Would this be a suitable place to tap into my hydraulics for rear remotes. I'm dreaming about a hydraulic top link, and perhaps hydraulic controls for the chute on my rear blower.
/ Tapping into my hydraulics #2
I cant help you with the hydraulics part. but you might consider using electric motors to move the schute on the blower. there are several links in the search here. I can also tell you about mine. I used a wiper motor. and works good. no hoses or valves to deal with either.feel free to message me if your interested.
/ Tapping into my hydraulics #3
I do not know how good your manuals are (or if you even have them), but
you will most likely need a hydraulic diversion plug if you use those ports.
Does you tractor have a loader valve? Your photo does not look like the
Yanmar (JD) tractors I have added remote hydraulics to.
Unfortunately, i do not have a service manual for my tractor.... though i should get one. The plugged ports under my seat are in the block where the pressure line goes into the rear of the tractor to power up the TPH. I don't think it would be a huge issue if using this port to power rear remotes would only allow me to use one valve (or the TPH) at a time...... as i don't forsee me wrestling two or more levers on the rear at a time. I was hoping someone here had used these, and could tell me if this would be an acceptable way to get hydraulics to the rear.
/ Tapping into my hydraulics #5
Hi Ductape,
I've copied the hydraulics page out of the Yanmar ym186d instruction manual for you......hope this helps......regards from over the water....Dean
Dean,
Thank you very much. Some of it is not clear enough to read, but having the diagram showing where the return lines go is a big help ! I'm really stunned that no one here has done this....... or not offered any advise. Any chance you have aux. hydraulics on your tractor? Just curious if affected the three point hitch in any way. I need to find an OEM manual for my tractor.... i missed one on Ebay a while back !
Scott
/ Tapping into my hydraulics #7
You might give a PM to MadReferee
He may not have seen your post, He seems to be very knowledgeable with Hydraulics.Wish I could help.
Allan
Bedlam, I'm WAAAAY ahead of ya !!! Now that i have the schematics of it, hopefully with a little help i can get this done. He certainly seems to be the self-taught master of hydraulics !
Dean, could i get you to tell me what size fittings are required on the divider block? Its too blurry to see..... i belive this is "C" on the bottom left of the page. Also...... the return plug..... looks like 3/4-16 UNF w/oring ?
Thanks again !
/ Tapping into my hydraulics #10
Thanks again !
3/4"-16 = SAE 8
You should get a male o-ring SAE 8 to female of whatever male end your hose has. These types of adapters are common and should be available at any place that sells hydraulic fittings like DiscountHydraulicHose.com
/ Tapping into my hydraulics #11
Deanbro said:
Hi Ductape,
Excellent picture! This is exactly what you need, Ductape. Note the
socket head diverter plug you need. In my JD hydraulic conversions,
this was the only part I needed to buy from JD, due to the strange
thread and length. All the other fittings are std ORBs, as stated. I noted
two other interesting items from the manual page. The 3-pt is downstream
of the hyd access ports, which requires the use of an aux valve with
power beyond. If the 3ph is upstream of the access ports in this
open-center system, then you can use a simpler valve with no PWB port.
Second, the manual warns of breaking the hyd pump if you block the
circuit thru the valve. This implies that there is no system relief valve. That
is a scary thought. Hard to imagine that Yanmar does not have a RV
in the circuit.
Anyway, great documentation! I wish I had similar for my Kubs, JDs, and
Kiotis.....
/ Tapping into my hydraulics #12
Hi Ductape,
The output of your Hyd Pump is 4.8 U.S. GPM (18.2 litre per min) @ 2600rpm
and yes, the unions are 3/4UNF Thread.
I currently don't have rear remotes on my 186 as yet, i just bought a hydraulic top link and spool valve which i intend to fit over this next week, i'll take some pic's and post here when i've done which may help.
If it helps, i could photocopy my manual and mail a copy to you , PM your address and i'll have it to you in three or four days
Regards......................Dean
2022 ALLIANCE NORTH AMERICA SDG45 GENEEATOR (A65643)
2022 ALLIANCE...
Metal John Deere Birdhouse (A65583)
Metal John Deere...
2022 EZ-GO ELITE...
Sudenga 10 x 63 Portable Swing-away Auger (A66408)
Sudenga 10 x 63...
2016 Ram 5500 Flat Bed (A63689)
2016 Ram 5500 Flat...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
