Tapping into existing hydraulic pump to run a PTO motor
   / Tapping into existing hydraulic pump to run a PTO motor #21
Probably just trade up to bobcat toolcat 5610 to handle both implements simultaneously.
   / Tapping into existing hydraulic pump to run a PTO motor #22
I don't think you can run the front hydraulics and rear hydraulic pto at the same time though.
   / Tapping into existing hydraulic pump to run a PTO motor #23
I have a Mahindra 4510 that has 9.6GPM from the pump and 4.3GPM for the power steering. I was wondering if I could tap into the pressure line that feeds the 3 rear remotes, add a 'T' fitting and a hydraulic solenoid that I can turn on and off to power a front mount PTO motor.
1) Do I have enough flow to do this?
2) What size PTO motor should I get to run a 7ft finish mower?
3) What type/size solenoid should I buy?
4) If this isn't the thing to do, could I add a pump that is driven right off the crank? (18 spline, 1" output shaft on end of crank)
Are you cutting with full 7 ft on your finish mower?
Is this the same mower that swings around trees?
If yes I believe rule of thumb is around 5 HP per foot of cut and that varies depending on what you are cutting. Using hydraulic drive figure minimum of 15 % power loss so you would need approximately 40 Hp hydraulic input to run your mower.
For reference rule of thumb: 1 HP can produce 1 GPM @ 1,500 PSI
2017 JOHN DEERE 310SL BACKHOE (A60429)
2017 JOHN DEERE...
2018 VOLVO L180H WHEEL LOADER (A60429)
2018 VOLVO L180H...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
Rooster Weathervane (A59231)
Rooster...
