Tap/thread sizes
   / Tap/thread sizes #1
BTackett
Knoxville, Tn
I am looking to drill/tap some M12 bolt holes on the hub of my Mits and wondering if I were going to drill/tap for a 1/2" bolt what size drill bit to use? Reason I am drilling is 4 of the 6 are already crossed. looks like someone tried already to use a standard bolt on Metric threads.
Also, what size to drill/tap to 5/8" bolt?
I found an old chart but it only shows up to 3/8 size.
thanks,
Bill
   / Tap/thread sizes #2
I don't think you will be able to use the 1/2 because the tap drill is smaller than 12mm. The tap drill for a 5/8-11 is a 17/32" (.5312). A 9/16-18 (.515 tap drill) would work too but it's a bit of an odd ball size. Hope that helps
Steve
   / Tap/thread sizes #4
Just a suggestion, If the whole tractor is metric I would keep it that way.
If you change some to standard yes you solve the problem today, but if in the future you or another owner have to replace those bolts for some reason or even just disassemble reassemble it complicates things when some are standard and some are metric.
   / Tap/thread sizes
tlbuser, I now have one of those laminated on my wall! thanks
I normally would not change std to metric but apparently the previous owner decided to do that with the left wheel and then used smaller longer bolts on the right side with washers/nuts on the back side. Not good. So , If I re-thread the right side back to metric and the left side is larger than M12 (5/8") then I would have std/metric rear wheel bolts. I just want to make both sides the same regardless.
thanks for the replies.
Bill
   / Tap/thread sizes #7
That makes sense. You are correcting the problem I was thinking you were going to create. All lug nuts the same is all the same wheather metric or standard.
Good luck
   / Tap/thread sizes #9
Helicoils are good idea if you want to get back to the original bolt size (M12) but you'll have to drill and tap the holes to the lager size. I think it's M16 for the M12 helicoil so make sure you've got the right drill/tap on hand.
   / Tap/thread sizes #10
A good rule to remember for Metric Bolts:
Subtract the pitch from the diameter to get drill size.
For example, the appropriate drill for an M6 x 1.0 would be 5.0mm.
Of course, most of us don't have metric drill bits lying around, so you still need the chart next to the drill press to find the equivalent Americaneze size drill bit...:rolleyes:
   / Tap/thread sizes #11
I dont know your tractor but I would look into drilling out the hole and putting in wheel studs. that way the studs could be changed if damaged and the wheels would be easyer to put on....Larry
   / Tap/thread sizes
Pacman, I looked today for studs but no luck. Mine has a 3 inch HEAVY spacer between the hub and axle also.
I went to the fastner store here and bought a 27/64 drill bit and a 1/2" spiral tap that should solve the problem. I would like to find some grade 5 all-thread and make me at least two studs as it makes mounting the wheel spacer/wheel a lot easier.
thanks for all the replies.
Bill
   / Tap/thread sizes #13
Bill
NICE CHART. Bummer that it doesnt show the metric fine threads. If it did yould notice the almost perfect crossover at 12mx1.25 and 1/2x20. The threads match. You can run the slightly larger 1/2" tap down the 12m hole following the original thread. Another almost perfect crossover upsize is 18mx2.5 to 3/4x10. Bummer that they dont show 18m on chart either. Its a standard, but less common metric size in coarse thread. These crossovers can be very useful to repair a damaged threaded hole.
larry
   / Tap/thread sizes #15
Danno1 said:
M5x0.8 and 10-32 are a very close match too.
Yeah, good catch. On that one the metric is bigger. Unfortunately not bigger enuf to fix a stripped 10x32 hole. :( ... Still valuable for upgrade - or to fix in early stages of damage.
larry
   / Tap/thread sizes #17
I have tack welded wheel stud heads in before. I would take a look at drilling out the threads and putting in a metric bolt from the back side and tack weld the head than use a lugnut to hold the wheel on. I dont like wheel bolts......Larry
   / Tap/thread sizes #18
Every wheel needs at least 2 studs to line it up as you put it on.
larry
   / Tap/thread sizes #19
welding in bolts like I said would give you all studs insted of bolts and threds that he having trouble with.....Larry
   / Tap/thread sizes
I agree with having studs. I am going to fill both rear tires with w/washer fluid and it helps to align when putting the wheel on. I also don't like to see just 2-3 threads on the backside of the hub.
Where can you buy STEEL bolts now days? Every where I look is Zinc and I don't like welding zinc. Maybe McMaster carr??
Bill
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2404 (A60432)
2404 (A60432)
