Tap a hole in plastic barrel?
   / Tap a hole in plastic barrel? #21
OK, more good information.
The barrel tipper is out. The upside down barrel is out. :)
Make a form to hold barrels lying on their side with a slight tip to it and the bungs vertically aligned and on the downward side with the small bung on the bottom. Plumb in the lower barrel bungs on a common line that goes to your pump. You can also use this line to fill barrels. On the top bungs put in a reducer and run a small line up from each bung to vent barrels.:D
   / Tap a hole in plastic barrel? #22
I was wrong, it was an 1.5" ball valve reduced down to 1.25".
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
