Tap a hole in plastic barrel?
   / Tap a hole in plastic barrel? #21
OK, more good information.
The barrel tipper is out. The upside down barrel is out. :)
Make a form to hold barrels lying on their side with a slight tip to it and the bungs vertically aligned and on the downward side with the small bung on the bottom. Plumb in the lower barrel bungs on a common line that goes to your pump. You can also use this line to fill barrels. On the top bungs put in a reducer and run a small line up from each bung to vent barrels.:D
   / Tap a hole in plastic barrel? #22
I was wrong, it was an 1.5" ball valve reduced down to 1.25".
49" X 79" EXPANDED METAL RAMP GATE (A54756)
49" X 79" EXPANDED...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2006 International 7400 Dump Truck (A47477)
2006 International...
2012 Infiniti G25 Sedan (A55758)
2012 Infiniti G25...
