Disc Harrow Tandem Disc Harrow Selection For Compact Tractors
   / Tandem Disc Harrow Selection For Compact Tractors #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
TANDEM DISC HARROWS (REVISED)​
Tandem Disc Harrows and PTO powered Roto-tillers are soil mixing implements. Roto-tillers are more effective tilling implements for subcompact and compact tractors up to 2,300 pounds bare tractor weight, typified by the Kubota 'BX' and 'B' series.
Disc Harrows come in numerous types. However, for 25-horsepower to 60-horsepower tractors the three point hitch mounted, Tandem Disc Harrow, secondary tillage implement, is ubiquitous.
Tandem Disc Harrows are manufactured in two structural types: angle-iron frame and Box Frame. Box Frame Disc Harrows are stronger, heavier, have greater adjustability of the gang angles and, having welded frames, are not prone to working loose like angle-iron frame Disc Harrows. If the budget allows, purchase a Box Frame Disc Harrow.
Good soil mixing requires Disc Harrow weight of 40 pounds bearing on each Disc Harrow pan, which arrives with pans at least 18" in diameter. Even with 40 pounds bearing on each pan, several passes over the land may be required to mix/till soil 6" deep.
February 28, 2013 I took delivery of a Howse*, box-frame, Tandem Disc Harrow, Model DLHT16822B. The dealer, from who I bought my tractor, recommended the Howse DLHT. At the time I was researching Disc Harrows from Land Pride, Everything Attachments (ETA), TSC/Countyline and Monroe Tufline.
Howse describes the DLHT series as MEDIUM DUTY. Howse DLHT is a 16/18 Disc Harrow, meaning 16 discs, each 18" in diameter, spaced 9-1/2" apart. It cuts a swath nominally 5'-6" in width, adjustable by sliding the disc hangers in or out. The Howse DLHT16822B weighs 587 pounds. It has a 1" axle on sealed flange bearings. (There is a T-B-N consensus that to cut vegetation Disc Harrows should have 40+ pounds weighting each disc. My Howse has 37 pounds weight per disc; except when tilling optimally moist soil I wish for more weight.)
My primary Disc Harrow objectives involve CUTTING; opening new game feed plots, maintaining vegetation free fire breaks and vegetation control along woodland trails. Harrow weight on 16 discs, rather than 20 discs, puts more cutting weight on each disc. Spacing between discs is 9". If you have rocky soil, 9" disc spacing will collect fewer rocks.
Tractor users with SMOOTHING (plow furrows) as their priority may consider the 20/18 or 20/20 configuration. Both have 7-1/2" spacing between discs.
Disc Harrows are available with two types of discs: notched and smooth. Notched discs cut pasture grass and crop stubble better; in open soil notched blades jerk out trash, meaning vines and tree roots, which sporadically stick in the notches. Smooth discs roll over some vegetation that notched discs cut through.
Standard configuration for Howse Disc Harrows is notched discs front, notched discs rear.
((Synonyms for individual discs: wheels or pans.))
Discs for compact tractor harrows come in 16"-18"-20"-22 diameter. Subcompact tractor owners will be better served by a PTO powered Roto-tiller rather than a Disc Harrow. Compact, 4-WD tractors with a bare weight of 2,700 pounds can handle 18" diameter notched discs. Tractors with bare weight of 3,500 pounds can handle heavier 20" discs; tractors with a bare weight of 4,500 pounds may opt for 22" discs. Weight is your friend.
Issues with disc diameter are concavity, wear, harrow weight and clearance lift. Smaller diameter discs generally have less concavity (less "float") than larger discs, so they theoretically penetrate easier; smaller discs are thinner/sharper than larger diameter discs. Larger diameter discs generally have greater concavity, so move more soil laterally. Larger diameter, thicker discs wear longer before requiring replacement. Larger diameter, thicker discs add to harrow weight, which offsets "float", improving penetration.
Replacement 18 inch discs are available in 3mm, 3.5mm, and 4mm thickness. Replacement 20 inch discs are available in 3.5mm, 4mm, 4.5mm, 4.76mm, 5mm and 6.35mm thickness. As shown, diameters and thickness overlap. Thicker discs are heavier. (Agri-Supply offers 516 individual disc types on its web site.)
Discs of larger diameter require more lift from the three point hitch. Clearance can be an issue when crossing ditches, rough ground and loading or unloading a tractor mounted Disc Harrow from a trailer.
The three point hitch Top Link is used to adjust relative front/rear gang pressure on soil. Shorter Top Link, more soil pressure from front gang. Longer Top Link: more soil pressure from rear gang. When pulled at a good pace the front gang flings soil outward, the wider rear gang flings soil inward. I use my Disc Harrow for dirt road maintenance, with Top Link adjusted long so soil is collected from high road edges and thrown inward.
Some increase in pan penetration can be achieved by shortening the 3-Pt. Top Link until the rear gang is raised into the air, transferring rear gang weight to the front gang. This can be helpful penetrating vegetation on the first pass across a field.
My Howse has a dropped double clevis (two "ears") to receive draw pins. A dropped clevis is desirable on a Disc Harrow for an 25-60 horsepower tractor; it allows the 3-Pt. to lift the harrow earlier. Note Photo showing my Howse in the air. Minimum disc height above ground is 14-1/2", greater than 14" ground clearance of my B3300SU tractor. This is ideal.
I prefer a wide double clevis, which accepts separate draw pins, to protruding, bolt-on "open" draw pins. The double clevis provides a stronger tractor/harrow connection, which distributes draft strain. TSC/Countyline by Tarter, 84 Disc Harrow, suitable for a tractor larger than mine, has "open" draw pins protruding from the harrow frame; in a "normal", undropped position. The Land Pride DH1560/60 has dropped "open" draw pins. Wider Land Pride Disc Harrows have preferred double clevis standard.
The Howse, with its 3" wide, dropped, double clevis is the easiest implement I own to mount on the three point hitch.
Most 5'-6'-7' Disc Harrows provide gang angle adjustment via clamp plates and adjustment holes in the frame. Clamp plate adjustment is simple, strong and inexpensive to manufacture but time consuming to adjust in the field. While the need to change gang angles will vary by user, adjustment is NOT an everyday event for me.
My Howse has five adjustment holes in the frame per gang, some brands have four.
Clamp plate adjustment works via three through bolts/nuts per gang, clamping twinned upper and lower adjustment plates, which have a pair of rib guides on the top plate mirrored by a pair of rib guides on the bottom plate. To adjust one gang angle, the two outer bolts/nuts are loosened with a wrench, the center bolt, which passes through adjustment holes in the frame, is removed, then the gang is pulled and jiggled to line up holes in sliding adjustment plates with alternate holes in harrow frame, using gang length for leverage. The center bolt is replaced and all three bolts/nuts tightened with the wrench. Repeat for the second gang. {Loosening/replacing bolts/nuts is a 15 - 20 minute process.} I have applied wax lube to the harrow frame over which the adjustment plates slide. New, it adjusts easily. I understand with paint abrasion, rust, dust, deformity, etc., gang adjustment becomes harder. However, I will settle on a 'default' gang angle setting soon and only change gang angles occasionally thereafter.
Some TBN threads suggest substituting a 5" pin as a pivot, in lieu of the center bolt. With only a center pin, it seems possible the center support could "jump" the guides under load; stay with the center bolt and nut.
Three Disc Harrows could be accurately described as HEAVY DUTY in relation to compact tractors by design and by weight. All adjust gang angles easier than the common friction plate arrangement. If you will disc several soil types it is worth paying for quick adjustment.
Everything Attachment's ETA-XD-BF-DH-16-18 disc harrow weighs 686 pounds (43 pounds/disc) and is priced at $1554 delivered to Fanning Springs, North Florida. The ETA disc has two, long, gang adjustment screws, one adjusts each gang. I admired ETA screw-adjust disc at the 2012 Sunbelt Ag Expo in Georgia.
I have purchased several implements from ETA. I respect ETA's quality and excellent customer service.
Leinbach box-frame disc harrows use an identical screw adjustment.
Monroe Tufline's THE71618BF disc harrow (1-1/8" axle) weighs 670 pounds (42 pounds per disc) and was quoted at $2100, plus a local delivery charge. Tufline promotes lever adjustment of the gang angles. I researched the Tufline 'THE' discs on Tufline's very basic web site. I have not seen a Tufline with mine eyes but the Tufline brand enjoys an excellent reputation. Monroe Tufline makes a huge range of Harrows for CUTS through Big-Ag.
Brown Manufacturing Corp., Ozark, AL, produces the BDH-600-1620 Disc Harrow (1-1/8 axle), 6?4 width, 1095 pounds (68 pounds per disc!) with lever gang angle adjustment priced at $2535 FOB factory. I researched Brown's BDH Disc Harrow on Brown Manufacturing's web site.
Price is not the first priority when I purchase attachments. However, my Florida rock free, sandy-loam is not challenging to disc so I bought the Howse DLHT as adequate and a good value. I paid $950 delivered. (No sales tax in Florida on ag or forestry equipment.)
Pulling a Disc Harrow is high draft force work. Not only is the implement weight being pulled, but the discs are resisting passage through the soil, proportionate to gang angle adjustment. To optimize soil mixing a Disc Harrow must be pulled at a brisk pace.
I pull the Howse behind a Kubota B3300SU tractor/loader. ( 33-hp / 1,900 pounds bare tractor / 4-WD / 58" tire width ) Tractor and Howse 587- pound Disc Harrow are well paired.
The B3300SU is in HST/MED range pulling the Howse. In repeatedly cut soil, in which the Disc Harrow will sink deep, additional throttle is required to keep the B3300SU from bogging down. Infrequently, I need to lift the Harrow just a tad. Adjusting gang angles to a less aggressive setting will reduce draft force.
Disc Harrows are frequently used to prepare game food plots. For food plot preparation, where you will maneuver between trees and boulders and work on slopes, buy a disc no wider than your tractor's rear tires. Any wider and the tractor will pass through gaps but the disc will "hang up" and you will waste time extricating tractor+harrow combination, possibly banging up your tractor in the process. It is important to buy a heavy enough Tandem Disc Harrow, which is really a secondary tillage implement; it is rarely practical to make a second pass over food plot ground. Fortunately, plot seeds are eager germinators.
It is important to tighten the four axle nuts regularly on a new disc harrow; they loosen. If the four axle nuts are tightened regularly the entire gang assembly will settle-in eventually and thereafter axle nuts require tightening infrequently. If axle bolts are not kept tight, disc hubs and axles will work each other, ruining one or both.
A test for tightness involves "ringing" the discs with a mallet when the harrow is elevated. A loose disc will give off a flat tone.
*Howse declared bankruptcy, then liquidated, after this was written in 2014.
Photo #1 Howse DLHT 16822B
Photo #2, #3, #4 Clamp Plate adjustment of gang angles.
Photo #5 "Double Ear" dropped clevis.
Photo #6 Lift clearance.
Photo #7 Short Top Link, rear gang lifted, transfers additional weight to front gang.
Photo #8 Howse behind Kubota B3300SU.
Photo #9 Howse behind Kubota L3560
Picture below shows ground tilled by my 16/18" Howse Disc Harrow pulled at a brisk pace.
The soil thrown out by the pair of sharply angled front gangs is clearly visible, as a lapping wave nearest the tractor. The little furrows are where the ouside pans of the rear gang picked up soil to throw inward.
Location is a firebreak surrounding a community burn pit which I maintain vegetation free.
Nebrfarmr
Veteran Advisor - Successful Farming
‎09-22-2011
Re: Disc spacing
We have both a 9" and 7 1/2" spaced disk, both are older IH disks, so they are built similarly.
Wider spacing - goes deeper, pulls just a little easier for the depth you are going, doesn't plug. Usually with the wider spacing, you go with bigger blades. When ours wear down a bit, we sometimes move them to the narrow spacing disk. The disk itself is narrower, so the number of blades per gang is the same. Chops through heavier residue easier.
Better for going deep, and burying some stalks.
Narrower spacing - smoother seedbeds, doesn't make as big of clods if the ground is a little wet, cuts stalks into smaller pieces, but will plug sooner in heavy trash. In wet conditions you better be sure the scrapers are in A-1 shape, at least on our soils. One pass with it on bean ground leaves the ground as smooth as 2 passes with the 9" spaced one. However, in heavy cornstalks, and deep ridges, it is hard to get it down deep enough to chop the stalks in the bottom of the ridge all the way through in tough conditions.
Have 8 acres of uneven and some areas rough hard as **** dirt. Discing, ripping, scraping, leveling out a few areas and moving dirt around. Building some width to an existing driveway among other small farming stuff.
Discing, ripping, and leveling moving dirt around will be the most use until itç—´ maintainable. Rototilling some smaller areas and of course lots of mowing.
As your ground is HARD plow it as the first step. A Moldboard Plow will loosen the soil for leveling and bring up micro-nutreints and incorporate them into top soil. You can buy a plow or have your eight acres plowed on contract. Ripping should not be necessary if you plow.
Disc Harrowing is the next step after plowing. Disc Harrow will knock down the deep plow furrows and commence leveling the ground. For use behind a 4-WD Deere 1070 I recommend a Disc with 20" diameter pans and a width of 84".
In the southern half of USA few would plow more often than once every ten years.
An ADEQUATELY HEAVY Disc Harrow is useful for soil preparation throughout the year.
Few with Disc Harrows adjust them after putting them to use. If you first process the field two or three times (depending on the weight bearing on each of your disc pans) to loosen ridges, then adjust gang angles less aggressively in increments, the disc may meet your leveling needs solo. ( In your case, plow.)
Moist soil will make your project go faster.
Adjust Top Link to vary disc weight distribution. Shorter = more weight on front gangs. Longer = more weight on rear gangs.
More weight on front disc gangs throws dirt OUT. Run down ridges.
More weight on rear/wider disc gangs gathers dirt IN. Straddle the swales.
The faster you disc the more dirt is moved.
As the field is smoothed, adjusted disc gang angles to progressively less aggressive angles.
As the field is smoothed, adjust Position Control so disc is in lighter contact with the soil.
Disc Harrows and PTO powered Rototillers are both soil mixers. No need to have both.
For the tasks you have enumerated, less PTO-rototilling, tractor weight should be your first consideration.
   / Tandem Disc Harrow Selection For Compact Tractors #6
A really informative post, Jeff. Thank you.
I found what I believe to be a Massey #25 disc.
Would this be a good match to my NH TC45d hydrostatic?
New Holland TC45
2001 - 2003 Boomer TC Series
Compact Utility tractor
Next model: New Holland TC45A
Manufacturer: New HollandVariants:
TC45: base model
TC45D: deluxe
New Holland TC45 Engine:
Shibaura 2.2L 4-cyl diesel
New Holland TC45 Power:
Engine (gross): 45 hp [33.6 kW]
Gear PTO (claimed): 39.6 hp [29.5 kW]
Hydro PTO (claimed): 37.8 hp [28.2 kW]
Capacity:
Fuel: 13 gal [49.2 L]
3-Point Hitch:
Rear Type: 1
Rear lift (at 24"/610mm): 2330 lbs [1056 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Dimensions
TC45 2WD Weight (shipping): 3,200 lbs [1451 kg]
TC45 4WD Weight (shipping): 3,349 lbs [1519 kg]
TC45D 4WD Weight (shipping): 3,417 lbs [1549 kg]
TC45D SuperSteer Weight (shipping): 3,586 lbs [1626 kg]
Wheelbase: 73.5 inches [186 cm]
SuperSteer Wheelbase: 81 inches [205 cm]
Length: 125.2 inches [318 cm]
SuperSteer Length: 129.6 inches [329 cm]
Width: 61.3 inches [155 cm]
Height (ROPS): 95 inches [241 cm]
Ground clearance: 14 inches [35 cm]
Front tread: 46.4 inches [117 cm]
Rear tread: 47.5 inches [120 cm]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: hydrostatic power
Cab: Two-post ROPS.
Hydraulics:
Pump flow: 9.8 gpm [37.1 lpm]
Total flow: 14.9 gpm [56.4 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
Page information:
Last update: October 31, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: Peter@TractorData.com
If your MF TC45d has 4-WD it should pull an 8' width disc with 18" diameter pans fine.
The eight foot width with 20" diameter pans may be too much. Your TC25d may run out of traction/power with gang angles set aggessively or on second pass when soil is soft. Border line case.
The eight foot width with 22" diameter pans -- too much.
Bear in mind that I do not know your exact conditions.
What diameter are the pans and what is your pan spacing?
18" is about 37 pounds bearing on each pan. 20" pans 52 pounds bearing on each pan.
7" pan spacing has more float than deeper penetration 9" pan spacing.
Big differences in draft force resistance.
In terms tractor capability, tractor weight is the primary factor. 4-WD vs 2-WD and tractor horsepower are not unimportant, yet secondary, pulling a Disc Harrow.
In terms of the disc, the draft force (implement resistance) is proportional to pan diameter, pan spacing (7" or 9"), disc width, and gang angle adjustment.
Then there is your soil and soil moisture.......tire type, tire weight, tread sharpness.......
Your tractor weight and width is the same as my Kubota L3560.
Tire width is probably 64". So two disc widths choices are 72" and 84". 84" disc is 17% wider/heavier than 72" disc and will require about 17% greater tractor traction and power to pull with all pan diameters and all and pan spacing.
I'm kicking myself for not taking pictures of disc when I was there. I believe it's 9" spacing and 18"diameter pans. Thanks for your help. As far as weight goes, does leaving the loader and grapple on the front increase weight in a useful way relative to pulling a disc through soil?
FEL certainly increases tractor total weight, but FEL acts as counterbalance to your loaded rear tires, so combination when pulling a disc harrow may be neutral or somewhat helpful.
I remove my bucket for forward visibility when harrowing for an hour or two. I remove the entire FEL for forward visibility if I anticipate harrowing four hours or more.
   / Tandem Disc Harrow Selection For Compact Tractors #8
In this day of no till farming practices, mold board plowing is rarely done as is heavy discing unless it is ground that has not been farmed in many years. Erosion is now believed to cost as much or more nutrients as you gain by 6”-8” or deeper depth plowing. If your desire is vegetation control, consider rough cut mowers (bush hogging). If wanting food plots then consider light/shallow discing or perhaps light chisel plowing. If gardening then a PTO tiller but only for about 4-6” depth. Then consider a mulch covering of compost, grass and leave clippings. These types of coverings around plants will add much more nutrients than you will ever bring up by tilling deeper. Also they add topsoil as the break down over the years and slow the process of erosion.
While farming implements of yesteryears are sometimes fun to play with and dream about our childhoods, I have no desire to return to the mule plowing that my father did as a teen and young adult.
   / Tandem Disc Harrow Selection For Compact Tractors #9
Excellent information. I have a light disk, but my use is light duty. I'm not breaking any new ground; I have a well established large garden, and use the disk in the fall to chop up and turn over the plants. I leave it that way all winter...a bit of trash and rough ground. Then in the spring, another disking to chop up the dead plant material some more and then tilling to prepare the seedbed. You alluded to the point that you need to move at a brisk pace...that is a key point. The disk is designed to "throw" the dirt, and turn it over. For disks to work properly, you need have your speed up.
   / Tandem Disc Harrow Selection For Compact Tractors #10
I'm borrowing a howse angle iron frame disc from my neighbor. Just doing some light discing to put in some food plots for the fall.
I have a B2650 and was wondering how I should set my stabilizer bars (I think thats what they are called. Allow the lift arms to swing back and forth. Mine are the telescopic ones. They adjust with pins).
Should I pin them so the disc can't swing back and forth? Use the oval holes so there is some side to side motion?
Thanks in advance.
LOT: Torch Cart w/Gages, Hose, Torch Head (TANKS NOT INCLUDED) (A59076)
LOT: Torch Cart...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
LOT: (9) Tires & Rims: 275/80 R22.5, 275/70 R22.5 and other sizes (A59076)
LOT: (9) Tires &...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2001 TALBERT TRI-AXLE RGN TRAILER (A58214)
2001 TALBERT...
1286 (A58374)
1286 (A58374)
