Taking up electric fence
   / Taking up electric fence #1
robbyr
western east central texas
ford and mahindra
We have forty acres leased with some cows on it. The property is rectangular with the back fence probably somewhere between two and three times longer than the sides. Needed to take two strands of electric fence wire down and have been thinking on how to do it for a couple weeks. I made use of an old plastic water hose reel that probably hasn稚 been used in 10 years by strapping it in the back of our side by side. It worked pretty good although my arm was starting to tire. Feel free to laugh at the redneck ingenuity.
   / Taking up electric fence #2
I'm not going to laugh. I wish I'd thought of it. I used a coffee can, some all thread, and some crossed 1X2 pieces to make something similar for the same purpose.
   / Taking up electric fence #4
Had a wire fence removed by a villain at a prison farm, he was told to keep the wire for other projects and went on his way.
End of the day there was a trailer full of 6' lengths of wire all neatly bundled and tied.
   / Taking up electric fence #5
Helped my neighbor remove four wire - half mile - barbed wire fence. He had borrowed a very special implement but his tractors were too big for the implement. Therefore the Kubota M6040 came into use.
It attached to the 3-point - PTO driven. The center of this "winder" expanded when winding up the wire. When done - the center collapsed - spit off a large "donut" of wound up barbed wire.
It worked well - EXCEPT - pulling all four wires at the same time was not the brightest idea. The "pulled" barbed wire snagged and tore out all the bunch grass, sage brush, everything else - within its reach. We were constantly stopping the operation and picking this crap out the the incoming wire.
We ended up with a "donut" of barbed wire weighing right around 400 pounds. He had no plans for future use of the wire and I would not have wished this donut off on my worst enemy. It wound up nice and tight but the four wires were constantly crossing over each other. Not a pleasant situation for future use.
I would like to see a pic of that 3pt implement. Sounds like that donut would best be taken to the dump.
   / Taking up electric fence #7
Next time I see the neighbor - I'll ask. He leaves these large donuts out in the open - in out of the way places. They slowly rust down to nothing.
   / Taking up electric fence #8
Here's a link to one. They are handy, just be aware if you have any thought of reusing the wire take one strand off the posts lay it out in the field and reel it up, then repeat.
If you wind more then one strand at a time it is junk and almost unuseable after.
Wire Winder Hydraulic PTO Spooler Roller Pro Tatch Cable Winders Winch Best Tractor Fence Barbed Smooth
What I have done which is not as nice or neat is lay a strand out in the field, start a good sized loop ( I like about 3 ft in diameter)
get 6-8 rounds of it rolled up nicely, use some twine and tie that coil in several places,
now start rolling that down the field snugging the loops up as necessary when you reach the end tie it well, you may need to tie the bundle a few times while winding.
I have also seen old tire rims used to wind wire up,
I haven't tried it but I have looked at the large electrical wire spools and thought they would be nice to use for that, set them on a couple of stands and hand roll them pulling the wire in and on to them.
I have done that before as well except after so many loops I wrapped it with tape. Then roll some more and tape some more. I figured after a quarter mile of doing that it would resemble a bird nest so wanted to try something different. Also saw an old TBN thread where it was mentioned you could remove the back wheel on a truck, put an old rim on it, then put truck in low gear to spool it up.
   / Taking up electric fence #10
My electric fence runs are not that long and Im using aluminum wire so I use those orange cord reels to take mine up. But I do have an old hose reel and that may be quicker.
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
