Taking back my pasture....
   / Taking back my pasture.... #1
pokerboy57
John Deere 3320
I purchase a home in central florida which included several acres of weed infested pasture. The pasture is supose to have bahia grass. It's there amoung the virtual plethora weeds....I started taking it back by applying a Lesco weed and feed.
What does lime do for a pasture and when should it be applied ?
   / Taking back my pasture.... #2
lime is a PH modifier.
it should be applied after a soil test has been done and after it indicates that lime is needed.
   / Taking back my pasture.... #3
X's 2.
Without a soil sample your likely throwing $$ away. Better to spend $15-25 getting it checked than throw Lime and Fertilizer at it. When you send it in, they usually have a space for you to describe your crop so they can tailor your application rates to that crop.
   / Taking back my pasture.... #4
If your test indicates that you do need lime, it can be applied at any time. It takes quite a while to fully raise the pH. The actual amount of time depends on the lime itself, not all of it is equal.
   / Taking back my pasture.... #6
Regular mowing will beat back the weeds and give the bahia a boost. Don't worry, bahia will come back if you give it half a chance.
   / Taking back my pasture.... #7
Most (all?) land-grant universities offer soil-testing services, either at no charge or for a nominal fee. You should be able to pick up the soil-test kits at your local Cooperative Extension office.
Good luck.
Steve
   / Taking back my pasture.... #8
I like ryegrass for the cool weather and bahia for the warm weather. I let the ryegrass go to seed in the spring before I mow it. The bahia will emerge when the weather is really warm. Bahia is tough. Mow the fields regularly and it will beat out anything except, possibly, Johnsongrass. I mow the Johnsongrass patches even more regularly. I use no fertilizer or herbicide.
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
