Taking a bushhog off the 3 pt hitch
   / Taking a bushhog off the 3 pt hitch #1
johnnyreb
I am having trouble getting the bushhog off my B3030 3 pt hitch. The ball hitch that slides over the attachment pin on the bushhog is stuck solid to the pin. The swingarms are loose, and there is no pressure on the ball / pin. How is the best way to get the ball hitch loose?
   / Taking a bushhog off the 3 pt hitch #2
You did not mention how long it has been since you last took the bush hog off. If it is not rusted to the pin, I'd just give it a few solid whacks with a big hunk of wood or sledge hammer to persuade it to let go. If it were possibly rusted then use some penetrating oil for a day and then move to the whacking strategy.
   / Taking a bushhog off the 3 pt hitch #3
I use a rubber mallet to whack at the hitch arms so as not scratch the paint.
   / Taking a bushhog off the 3 pt hitch #4
You are going to have to beat it off there with whatever it takes, depending on how stuck it is. I'd be more concerned about why it's stuck?? Maybe you have bent the pin??
   / Taking a bushhog off the 3 pt hitch #5
Might be rusted on if hasn't been taken off for a while. Try WD-40 or similar penetrating oil first. Then place stout piece of wood on lift arm and hit it with a sledge. If it doesn't come off, try bigger sledge.:D
   / Taking a bushhog off the 3 pt hitch #6
If you can't beat it off with a bigger sledge, you can always cut the pin with a fire axe and drive it out then. New pins are not real expensive.
   / Taking a bushhog off the 3 pt hitch #7
johnnyreb,
Sorry if this sounds like a stupid question, but have you taken the sway pins out of the sway links? When dealing with a new piece of equipment, there can be a lot of new things to look at.
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2012 International 4300 Reefer Truck (A55301)
2012 International...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
40006 (A53422)
40006 (A53422)
