taishan ts254
/ taishan ts254 #1
gonefishin1
East texas
ford 4610, ford 2120, ts254 (Chinese)
I have a 1995 ts254 that i'm trying to get parts for. I've done a lot of searching on here, but most of the posts are old...
Where is everyone getting parts for these in the US?
I have contacted artrac and he doesn't have the radiator cap that i really need.. I haven't been able to find one anywhere. Does anyone have a lead on where to find one or a cross reference to one that will?
here are the other parts i'm looking for if anyone knows of a good place to locate them.
1 pilot bearing
2. throw out bearing
3. diesel return line from injectors to the tank
4. diesel line from filter to injection pump
5. waterpump and gasket
6 oil filter
7 tie rod ends all 3.
8. transmission input shaft seal
9. 2 gaskets inside of belhousing on transmission.
10. bellhousing gasket
11. clutch return spring.
12. radiator cap
I have 8-11 marked on a diagram
Also has anyone ever added a tach to one of these?
Thanks everyone.
  • tractor parts diagram.pdf
/ taishan ts254 #2
What engine does it have ??, if you are in Houston you can Drive up to Bellville about 60 miles from you and see what we can match up for you, we have 2-large warehouses full of parts for the Jinma and Foton tractors, and several different engines.We may be able to help you out with some of the parts you need
Bring your old parts with you
Tommy
Affordable Tractor Sales
6972 Hwy 36 N
Bellville,Texas 77418
979-865-4002
