Taishan tractors
/ Taishan tractors #1
nineninefan
extreme upstate new york
none yet
Does anyone know anything about Taishan tractors? All that seems to be available on the net is company information. Anyone ever use one? How do you like it? Are parts available? What types of attachments are available? Where do you get them? Will these tractors accept brush hogs,loaders,mowers, ets.. from other manufacturers? I don't want to buy a tractor and not be able to get parts and attachments. Thanks for your input.
/ Taishan tractors #2
We are importing some Taishan tractors and parts now from China. If the tractor you are looking at has a Cat 1 hitch, than you should have no problem with most implements working OK. Is this a used tractor you are considering? If so what model? Parts are not as readily available as for the more popular Jinma brands, but there are several dealers capable of providing parts support. Taishan claims the largest share of Chinese home market, with 60% of under 30HP tractors sold there. We will know more when our first units arrive later this month! If you need anything specific please feel free to email.
artrac@centurytel.net
/ Taishan tractors #3
Bluechip, did you order Taishan tractors or Foton. Am i wrong or didn't they quit importing under the name Taishan with the New Holland lawsuit against them? I had heard that they were importing them under the name of Foton. Anyway, they look like a nice tractor and i would like to see how they compare with the other Chinese tractors. We need Consumer Reports or somebody qualified to do an article comparing Jinmas/Kamas/Fotons/Lenar/and Benye tractors. Then doing a yearly update on them to see how they have done. /forums/images/graemlins/blush.gif
/ Taishan tractors #4
It is the Futian tractor involved in the lawsuit...not Taishan. I guess Taishan and Kama are the same tractor. I'm waiting to see if Bluechip likes the Kama shuttle shift. /forums/images/graemlins/confused.gif
/ Taishan tractors
I'm considering a used TS-25. It does have a cat 1 3 point hitch. 25 hp 2cyl diesel. I will be maintaining 5 acres. I want to be able to put a brush hog and finish mower on the hitch and a loader on the front. I have no problem with buying a tractor from China. The cost seems low and everything I have read has been positive. All this importing is fairly new. I don't want to get stuck with a tractor and no parts. Or worse yet have the company go out of business.
/ Taishan tractors #6
I've owned a Taishan 25 for almost 15 years, mostly pulling a 72" mower but also using a bush hog, hole auger, scraper box, and pond scoop. It has run well with minimal problems. I also have 5 acres and it is the perfect size for what I use it for. The tractor comes with a box of common spare parts (brake shoes, gaskets, head gasket, etc.) but I haven't had to use many of them. All in all it has been a good value for me.
/ Taishan tractors #7
I to have a Taishan 324, up till now only minor problems. Tonight I was using the scraper blade to repair the washed out driveway. Blade locked in the up position. Tried working the relief bolt but still stuck. Anyone have any suggestions.
Tom in TN
/ Taishan tractors #8
I'm not familiar with that model. What age is is, which motor, and are there one or two levers to control the rear hitch?
//greg//
/ Taishan tractors #9
It is a Taishan 304 - Dragon 324 Model 2100 2 cylinder Diesel if all of this helps. Not sure which numbers I should go by. The control levers are on the right side of the seat. It has a Check valve and speed lowering control on the front below the seat.
Tom
/ Taishan tractors #10
If the check valve under the seat got locked up while an implement is in the up position you may have to find a way to take the weight off the 3PH in order to free it up to drop. A jack, another tractor with a loader or something else to negate the pressure the weight of the implement is putting on the 3PH hydraulics. Once there is no weight on the arms you an again try to loosen the valve under the seat.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
2005 John Deere 544J Articulated Wheel Loader (A59228)
2005 John Deere...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 Chevy Malibu Sedan (A59231)
2014 Chevy Malibu...
