Tailwheel vs impact gun
/ Tailwheel vs impact gun #41
not specifically that brand.. but the style in general. at work we had always rant he metal ones ( housing i know )... and last 2ys the mechanincs were buying the composite ones.... we are all vack to metal now. too many broke housings.. i'm sure half of that is from abuse / dropping...
/ Tailwheel vs impact gun #42
I am sure that is probabally more like 90% from abuse (dropping).
Would you just "drop" any other $300 power tool?? Electric grinders? Drills? Saws??
/ Tailwheel vs impact gun #43
I have an Aircat. They are pretty much equal to the IR when it comes to strength but not as expensive. It's cheaper than the IR but I think the Klutch brand guns are even cheaper. I've only seen them sold at Northern Tool so I was never sure if it's a Northern brand or just a brand that Northern sells. I have to disagree with those who say get a cheap 1" gun (or even a 3/4"). Size can matter. Just last week a mouse got under the timing belt cover on my Tundra and I had to remove the crank bolt. There was just enough room for my 1/2" gun, anything larger would have left me trying to use universals and extensions to find a way to get on it. I think the IR guns are great but when you are talking well over $200 for one that's kind of out of the occasional weekend warrior price range.
I think mine is the 1200 K (twin clutch). When I first got it I thought it felt weird. The usual hammering that the cheap guns do wasn't there, also it was very quiet. It just removed everything I tried. I have both a "top of the line" Craftsman given to me as a Christmas gift and a Dewalt electric wrench and neither comes close to the same amount of power. I ended up pluming in a larger quick disconnect so I could use a 1/2" air line for less restriction.
/ Tailwheel vs impact gun #44
When my brother was a Matco Tool Distributor, one day he was in a big truck dealership and a mechanic was up high on a ladder working with his half inch impact. When he finished, he let the impact part of the way to floor, and holding onto the air hose, he swung it back and forth a couple of times before trying to swing and release it onto his workbench. He missed and his impact wrench fell onto the concrete. Another mechanic laughingly said to my brother, "I'll bet a tool man hates to see that kind of thing" and my brother said, "Oh no, I like to see that; I've got a brand new one on the truck I'd be glad to sell to him.":laughing:
/ Tailwheel vs impact gun #45
uh.. no.. more like the 50% I said. I handle all the tool claims, purchase and removal from stock/inventory. I'm pretty picky about documentation, plus what I see going on in my own shop.
i don't try to drop ANY power tool. However I do know that I have seen air guns, especially, and sometimes grinders 'fall' ( get dropped' out of the innards of a piece of equipment, and hit the ground, shortly thereafter followed by a curse, and an employee climbing down out of the bowels of some big piece of yellow equipment or from the engine compartment of a big pete, to retrieve a tool.
I also have watched an air tool be lowered to the ground via hose, and then a mis judge and a drop to hit the ground.
ironically.. some of the most damaged area are the air inlets, and the buttons.. rarely the anvil area.. and then the housing and actual internal cyl/hammers..
/ Tailwheel vs impact gun #46
I have to disagree with those who say get a cheap 1" gun (or even a 3/4"). Size can matter. Just last week a mouse got under the timing belt cover on my Tundra and I had to remove the crank bolt. There was just enough room for my 1/2" gun, anything larger would have left me trying to use universals and extensions to find a way to get on it. .
I'll go out on a limb here and assume you didn't bother to check the context of my post. IE.. if you had some large , non reoccuring jobs that required hp.. etc. my post #36 states this...
IE.. if you have a 2" bolt you need to take out 1 per year.. don't spend 500$ on an IR 1" gun.. get the 100$ hf one.. .. i'd rather have a 100$ tool set 11.9m out of the year than a 500$ tool.
a good small gun is a great addition to any tool kit... it's just on some jobs.. a 3/8 gun ain't gonna do me -any- good at all.
I've drained a 60g air tank trying to get a stuck 5/8 bolt out using a 3/8" gun.. when a 1/2" drive took it out faster.. and a 3/4" drive buzzed it out before I could let go of the trigger.
a 3/8 and probably the average 1/2" gun has proven useless on blade bolts/nuts on my hogs...
/ Tailwheel vs impact gun #47
yep.. that's the kind of stuff I see.. mostly accidental drops or misses..
/ Tailwheel vs impact gun #48
Something that a lot of guys don't know about air tool ratings is the fact that the 90psi should be measured at the tool INLET. To check correctly, tee a gauge into the airline at the tool inlet then pull the trigger on the tool. It will amaze you how the 120-150 psi @ the tank falls far short of being 90 psi at the tool inlet with the tool running.
I've used Mac AW234 & AW434 impact wrenches all my adult life. I had to run my compressor @ 195 tank psi and use a 1/2 air hose to get the full 90 psi at the inlet. But I could break loose bolts that other guys couldn't dream of breaking.
Im not sure how big those guns are, but I suspect you used a fairly small tee and the hi velocity air past the gauge port lowered the reading.
.... Years ago I made a setup to test pressure drop at hi flow. I just dug it up and checked it out to refresh my memory. --- With a 50' 3/8" feeder hose having one QC it takes 150PSI to feed 92PSI to an open orifice 0.215 in diameter. Thats well over 50CFM. The actual ID of the hose is more like 7/16", but that may be normal for 3/8 hose AFAIK.:confused3:
larry
/ Tailwheel vs impact gun #49
I have always subscribed to the notion that you get what you pay for. I live by this when it comes to tools. Although retired now, when I'm hip deep in a D10 final drive, my tool had to work!!
Mac and Snap On are the only guns I used. Never had one fail me as long as I took care of it.
/ Tailwheel vs impact gun #50
larry
which is why I like 1/2" hose on an air gun...
/ Tailwheel vs impact gun #51
does it count if I say I've never had a failure of an air tool from harbor freight.. yet in many cases I paid a fifth of what a name brand costs?
To be fair.. I use them a fifth of what a pro mechanic would too.. ;)
the 'you get what you pay for' deal has another facet.
the average homeowner who may use an air gun 1/per month.. don't always need a pro gun that has the quality to be used 8hrs a day 40 hrs a week.. nor the cost ;)
/ Tailwheel vs impact gun #52
You're right, a 3/4" and 1" air gun will provide more power and you can buy a cheap 3/4" gun that will outperform most 1/2" guns. The OP said if he couldn't get his current gun working then he would buy a replacement. I got the impression that he didn't want to spend too much money, that kind of puts the IR guns off the list. To me that means what ever bought must be flexible enough to be used on as many jobs as possible to justify the cost. The gun in your picture is quite large. While it's a great option for removing the bolt on a brush hog blade it could be very cumbersome to do work on a car or truck. I don't think your opinion is wrong and I think it would make a great compliment to his 1/2" gun but since the OP is talking about a replacement not an addition in my opinion that means a more powerful 1/2" gun.
/ Tailwheel vs impact gun #53
if he doesn't want to spend alot.. he's limited to what he will get in powerfull 1/2" guns.. IMHO
that said. i don't think thereis much , if any, need for a 3/4 gun for the average homeowner / person changing oil on his car. etc
/ Tailwheel vs impact gun #55
The Aircat will set you back $170 with shipping, so no it's not cheap but there's enough information and reviews out there about them, they are sold all over the place, and you can get parts for them. I have never seen or used one but for $100 the Klutch could be a good option. If you have a Northern tool close by I would go look in person and ask about parts. There's Horrible freight's Earthquake and if you have a store close by you can use a 20% off coupon to get it for around $80.
/ Tailwheel vs impact gun #57
I Have had two HF air tools go to crap. One was a right angle die grinder. Seems the pot-metal or whatever they use to keep the head attached to the body dont work well. The head comes loose and grinds gears. It can be tightened back down, but does it again. Only gets worse with time until it dont work at all.
Other is the 3/8 air impact. Actually, the gun works fine. But the little snap-ring thing that holds sockets on broke off first day.
But other than that, my drill, straight die grinder, ratchet, cut-off tool, and air-hammer all work just fine.
/ Tailwheel vs impact gun #58
/ Tailwheel vs impact gun #59
I'd rather spend a lot now and know I have a good gun then buy a cheap piece of junk and it break and have to buy the good then. Like I said earlier I think the average homeowner can buy with a quality 3/8 gun today. Customers are always commenting how fast it is.
you can of course do whatever you want to do with your $.. but consider this concept.
gun a, brand name, suposed good quality due to name recognition, 500$
gun b, knock off brand, presumed less quality, 100$
situation 1, light homeowner use:
Under light use, both a/b may last a 'lifetime' spinning a couple bolts out a year.
end result.. one gun cost you 400$
situation 2, heavier use
both guns used much more frequently, after 2 years gun b needs replacing, gun a, starting to wear, but still going very well... 2 more years, gun b needs replacing, gun a very much worn. 2 more years, gun a dead, gun b also dead... replace.
where are you at? you have spent 400$ on gun b. every 2 years it's a new gun, thus new performance. You spent 500% on guna, and it steadly wore down to needing replacing. at half time of this event, gun b was brand new. gun a was half way thru usefull life. net result.. you are ahead by 100$
I've done this comparison on MANY types of tools used in a industrial / construction environment.
brush hogs for example. we USED to buy the expensive brand name models that cost 1200$ vs a 550$ king kutter or howse.
what did we find? A car rim on the side of the road, after you hit them a couple times.. don't really care of it is destroying a 1100$ 'bush hog' or a 550$ king kutter. after nearly 2 decades of research.. we ende dup saving money using lower priced hogs. death rate was very similar on machines up to 2x$ price range.
smaller tools? chainsaws? weed whackers? hand tools?
hand tools. a theif can steel a 3$ 1/4" drive ratchet set from harbor freight.. or he can steal a 50$ craftsman one... same amount of time... both have lifetime warranty ;) 1 costs my company more to replace. ( i've also found the theifs don't like to steal the 3$ chinese sockets either.. not something they can go pawn... ).. We've had thefts where the criminal went thru.. left low priced tools and took high priced ones. places that only had low cost tools were not touched. ;) )
when out on a job and I find no other way around welding a 2" socket to the and of a pipe to get down in a hole... i'd rather do so with a socket I can replace for 5$ than one that I have to replace for 35$.
when I need to torch a 1.25" wrench into a stubby to get to a bolt to hold it. or put an S bend in a 1" wrench.. I'd rather do it to one I can repalce for 5$ vs one for 35$
a 175$ poulan chainsaw looks about the same as a 350$ huskie AFTER it has fallen off a tailgate driving down the side of a road doing ROW maintenance... OR after dropping a tree across it. one just eats less of a hole in the job profits.
when they are both running with rent-a-drunks . both have the same approximate lifespans in number of hours used. weed eaters work out the same...
ps.. none of this is made up. This is just looking thru my tool file I've maintained over the past years here at work at a GC....
expensive is nce.
expensive doe not always mean quality.. but generally used to anyway.. expensive does always equal expensive however.
economy does not always equal cheap..
here's another way of looking at it.
If I as a contractor have to put a 2500$ tool set in each one of my service trucks, to set out on the MSTU road job i'm building outside your house... or I can put in 700$ worth of tools... what do you think that does tot he price of that road. which in turn.. what happens to the price of your special assessment tax on your property taxes? I save money.. you save money... there ain't no free lunch.
with todays tool manufactring tech.. many tools pour out of china anyway.. reguardless of who's name is stamped on them. if I can pay 1/4 and get a working tool and save everybody money down the line.... why not ??
btdt, got the greasy sweaty tshirt...
PS.. this isn't 1980 when a cheap pakistan or tiwanese socket set was 10$ and a craftsman was 30-50, and there was a HUGE difference in quality.
this is 2012, and a craftsman wrench for 30$ laying next to a HF wrench for 5$ both have hece en chine engraved on them and both ahve a warranty.. and may have come from the same factory.. and are quite possibly the same level of quality.
different ballgame. maechanics from the earlier part of the last century had a legitimate argument vs against owning a cheap tool.
playing field went thru a major leveling with rise of industrial technology overseas, and us farming out as many jobs as possible. you CAN get a high quality, CHEAPER tool nowadays....
/ Tailwheel vs impact gun #60
My first impact wrench was a half inch Harbor Freight gun that was a CP734 clone (or at least looked like it) with about half the power of a CP734. But it never failed to work and I had it for more than 20 years. I now have a Harbor Freight 3/8" air ratchet and a Harbor Freight angle die grinder. I don't use them a great deal, so they're all I need. I've owned Snap-on, Chicago Pneumatic, and Ingersoll-Rand products in the past. But if one of the high dollar tools needs repairing, you repair it or pay to have it repaired. If a Harbor Freight tool needs repairing, you just replace it. There's certainly nothing wrong with that.
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
2022 EZ-GO ELITE...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2022 EZ-GO ELITE...
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
