Tachometer Quit working JD 4400 tractor
   / Tachometer Quit working JD 4400 tractor #21
I have a 1999 4400 that I replaced the instrument cluster in with an aftermarket unit. The tach wouldn't work. After a while I found out that when the screws were tightened in the back to mount the cluster into the dash it pressed the cluster into the glass cover in front. So basically the tach needle was pinned against the front glass and couldn't move. I fooled with it until I could get clearance between glass and needle and it worked. No idea if this could be your problem but I thought I would offer it up for you to check.
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
International S1900 (A56438)
International...
John Deere 920 Grain Platform (A59814)
John Deere 920...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
