Tachometer Quit working JD 4400 tractor
   / Tachometer Quit working JD 4400 tractor #1
ohiogar
John Deere 4300
Am in the process of restoring a 1998 JD 4400 Tractor with around 50 total hours on it from new. I have about 3 hours run time on it myself.
The tachometer worked fine and just quit all of a sudden. The hour meter works fine.
ALL of the factory safety's are functional. This is a pre computer machine.
I believe that the tach works off of a pulse from the alternator. A Trusted auto electric motor friend
tested and said the alternator is just fine. I even tried with a second used alternator.
I have traced all of the wiring and it also seems fine.
ALL of the relays have been switched around with extra's and have no effect on system.
I am clueless here. Any Ideas appreciated.
Regards from Ohio
gary
   / Tachometer Quit working JD 4400 tractor #2
Is there any way to test the tachometer itself, that is a substitute input to see if it reads?
I really do not know
I have read that the hour meter works off of the power supplied to the tachometer
   / Tachometer Quit working JD 4400 tractor #4
If there is no mechanical cable driving the tach it probably does feed off the alternator - counts pulses or something - not sure. Are your hour meter and tachometer both in the same unit or are they two separate instruments? That can work both ways. Unless it's a broken wire somewhere, unless you are familiar with working on instrumentation you should send the unit out for repair.
   / Tachometer Quit working JD 4400 tractor #5
Try wiggle the plug at the back of the dash. Or pull it out and check for corrosion on the pins. Sometimes it's all it takes.
Thanks I have done that many times. I have been over under inside and out and it will not work. BUT the hour meter works which is confusing
It is a new aftermarket dash cluster. Under advisement it just felt right to put
a new unit on a tractor with so many obvious signs of low hours.
   / Tachometer Quit working JD 4400 tractor #7
A signal generator could be used to make the pulses.
I have no knowledge of a signal generator. will research it.
I believe there is a pole on the alterntor that supplies that pulse.
How would one test that?
Thank You
   / Tachometer Quit working JD 4400 tractor #9
You can get a meter from amaxon.com
You don't need the high dollar one just
get a cheap one for the price of the high
dollar one's u can get 4 or 5 cheapies!
willy
   / Tachometer Quit working JD 4400 tractor #10
It seems too simple, but doesn't the shop manual have a schematic?
BTW, does the JD4400/Yanmar engine clock measure "key-on" hours or engine RPM converted to hours? There doesn't seem to be any rule on this.
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2019Grove 9000-2 115T Crane (A60460)
2019Grove 9000-2...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
RoGator RG1100C (A56438)
RoGator RG1100C...
