Tachometer for BX2200
   / Tachometer for BX2200 #1
rjmatt
Kubota BX2200
Hello everyone. I'm new to the forum, and new to ownership of a tractor. I recently purchased a used BX2200 with a bucket, MM 54" mower, and real balast box. I'm learning so much from this forum, so thanks for that.
Here's my question, Has anyone ever installed a tachomenter on the BX? I feel like I'm operating blind when running my mower because I don't know at what RPM the motor is running. A friend of mine has a JD and it has a tach on the dash with a indicator for the 'best' rpm when running the mower.
Maybe I'm being rediculous about this, but I have to think there's an optimal RPM for the mower, and I'd like to find it and repeat it each time I cut my grass. Suggestions?
   / Tachometer for BX2200 #2
Welcome to TBN:D
One popular model is the Tiny-Tach. If you search you should find some good threads on them...
   / Tachometer for BX2200 #3
In thick grass when mowing I put the throttle wide open, back off a little when it is thinner or near rocks. It is made to run wide open though.
David kb7uns
   / Tachometer for BX2200 #4
Dave is correct. Just a little bit under full throttle will give you 540 rpm on the pto. I once consdered putting a tach on my BX23, but I never did do anything about it. In time I learned to listen to the tractor. If it sounds like I need a little more throttle I give it a little. But if I need 540 pto rpm, I run it just about full throttle.
Thanks guys. This is just what I needed!
   / Tachometer for BX2200 #6
Agree with the others; did this on my BX2200 and rarely even bother looking at the tach on my BX2660.
   / Tachometer for BX2200 #8
I have a TinyTach, NEVER look at it, listen to the engine, it will tell you when it needs more. I mow with the throttle wide open, and just about everything else too including the tiller, snowblower, chipper, etc etc. :D
Pallet of (15) 10 Lug Misc Wheels (A48837)
Pallet of (15) 10...
2008 Chevrolet Colorado Pickup Truck (A46684)
2008 Chevrolet...
2014 Peterbilt 337 Forestry Grapple Truck (A46683)
2014 Peterbilt 337...
2025 70in Dual Cylinder Grapple Skid Steer Attachment (A49346)
2025 70in Dual...
2011 Ford F-450 Liftmore Crane Service Truck (A46683)
2011 Ford F-450...
2018 Diamond C 16ft T/A Hydraulic Dump Trailer (A46683)
2018 Diamond C...
