TACH HAND STICKING
/ TACH HAND STICKING #1
REDPRIDE
GREER, SC
MAHINDRA 5530 / 1947 John Deere Model M
Any quick fixes for a tach hand sticking, thought I'd seen something on here about it before, did a quick search but didnt see anything. I have a 5530 2wd, can usually just give a "quick pop" with the palm of your hand and it starts working but if theres something I could do to fix that would certainly like to. Thanks for any info!!
/ TACH HAND STICKING #2
I'd check for lose connections first, reseating cleaning any connections as I checked them.
/ TACH HAND STICKING #3
I have a Kubota L4300 and had a sticky and bouncy tack a couple months ago. Turned out the tach was cable drive and the cable needed grease. It was easy to get apart and I used white lithium grease. Works like a champ now.
/ TACH HAND STICKING #4
A blow on the right side of the dash is the most expedient fix it seems. My 7520 has been doing this intermittently for about 1000Hrs.
larry
/ TACH HAND STICKING #5
I have a 4025 and have disassembled the dash to check connections for the very same problem. All connections were good. I think humidity plays a role in this condition according to my dealer. One time the temp gage stuck also. One quick rap usually solves the problem. Mine started at about 3 years of age and has been doing it for the last 6 months. A permant fix would be nice if someone has it. I think time plays a greater role in this condition than actual engine hours.
/ TACH HAND STICKING #6
My 2008 Mahindra 5525 has the same problem-- and my fix is the same as yours. However, it usually takes a half dozen whacks to get that POS tack needle to read upscale. You'd think Mahindra's engineering center could wrestle this little problem to the ground--but I guess it's not a high priority over there.
/ TACH HAND STICKING #7
/ TACH HAND STICKING #8
My 2007 5525 also has this problem with fuel gauge, tachometer, and temperature gauge. The digital hour meter is not affected. The tach accuracy has also become erratic. As last winter wore on its reading slowly dropped to the point where it was showing three hundred rpm at idle. Over spring and summer it has crept up past the normal eight or nine hundred to fifteen hundred while actual engine idle is unchanged. I think the needle may be slipping on the shaft but I don't really know. Slapping the housing on the sides and top (like flusher often five or six times) will usually get them going. Another poster suggested the paint on the stop pin might be sticky but I've seen the needles bounce off the pin when I whacked the the thing. I would change the whole cluster if I thought it would fix the problem.
/ TACH HAND STICKING #9
Same here--all three of those gauges on my tractor stick on the downscale stop pin.
/ TACH HAND STICKING #10
I find that a blow is more effective if the engine is at a fairly lo rpm.
/ TACH HAND STICKING #11
Im asked the dealer if a new instrument cluster would make sense, he said that it cost was prohibitive and to keep wacking it. I know that the first time I really need the tach it won't work at all. Well I guess I have my first complaint about this tractor.
/ TACH HAND STICKING #12
We have tach problem on our Kubota B2710 HST with 530 hours. About 150 hours ago the tach will bounce against the max RPM stop when operating at about 1800-2000 RPM. The problem comes and goes. Anyone else ever seen this? Dealer offered to change out complete instrument panel for almost $400. Guess they believe troubleshooting is a lost and low profit art.
Thanks
Rick
/ TACH HAND STICKING #13
My 3525 was doing the same thing. All of the gauges and tach were intermitten. Some one on here a while back said the needles were sticking to the post they rest on and to sand them. I bought a new cluster off an EBay store for around $150 or so, can't remember exactly how much. 10 hours and so far so good. They definitely have a problem with their gauges.
/ TACH HAND STICKING #14
The only time I ever had such a problem was with my first showroom new car; a 1962 Austin Healey Sprite. The dealer had to order a new tach, then installed it in the dash, and it worked just like the old one. The tach was cable driven off the back of the alternator, and the problem turned out to be the fan belt not tight enough and was slipping at certain RPM.:D
/ TACH HAND STICKING #15
I have the same problem with my 07 4500, tach sticks and I just slap the dash and it goes to working
/ TACH HAND STICKING #16
REDPRIDE
We have a relatively simple fix. Remove the cluster from the tractor, remove the cover from the cluster, find a WD40 dispensing straw, cut the straw in the correct lengths to fit over the "pegs" in the instrument cluster, apply the straw pieces to the pegs, reassemble. The needles on the instruments will not stick to the WD40 straws. Just my $.02
/ TACH HAND STICKING #17
REDPRIDE
Neat fix. I wonder if Mahindra will take notice and add direct the vendor who makes these dashboard displays to incorporate your fix. I'm not holding my breath:confused2:
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
Great Dane Van Trailer (A63689)
Great Dane Van...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
iDrive TDS-2010H...
