TA T/A ? (quick dumb question)
   / TA T/A ? (quick dumb question) #1
BCJohn
IH Hydro 86, MF35, MF135
I've searched a lot about my Hydro 86 and can't figure out what the TA or T/A is. Is it the speed setting control and if so, what does TA stand for?
Thanks very much for any help
   / TA T/A ? (quick dumb question) #2
T/A = Torque Amplifier. Shift on the fly Hi/Lo. Works good when working. Money pit when not.
   / TA T/A ? (quick dumb question) #3
Torque Amplifier. It was IH's term for a two range shifter that you don't use the clutch for. I doubt if it was available on their Hydro tractors, just gear drives. Started out on the Farmall M (MTA) and stopped maybe in the 86 series or later gear drive tractors.
   / TA T/A ? (quick dumb question) #4
Torque amplifier, it has gear reduction on the shaft in the transmission that lowers the speed and increases torque most T/As will not hold you back in a hill in low. and you don't have to use the clutch to shift it.
   / TA T/A ? (quick dumb question) #5
I guess the IH T/A is equivalent to Massey Ferguson's Multipower shift on the fly setup. Both features showed up in the 1960s, IIRC.
   / TA T/A ? (quick dumb question) #6
I know but the IH is cheaper to fix it's a self contained unit that comes out in one piece I think Formsprag made them for IHC
   / TA T/A ? (quick dumb question) #7
T/A's built after 1963 do not freewheel, at least the ones installed on 70 HP and up tractors, and those installed on Doncaster-built utility tractors. The original mechanical T/A will allow freewheeling in T/A mode, but except for a very few models, this type disappeared from new tractors in 1963.
And certainly no hydrostatic drive IH's ever had a T/A.
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
