T7 SSQA, 9" hoe bucket and tie rod ends DIY
   / T7 SSQA, 9" hoe bucket and tie rod ends DIY #1
solo machine
Lima, Ohio
2007 Terramite T7
I have a 2007 T7 with a Kubota diesel. I bought this from a rental center, so a few issue's with it, not bad. First thing I replaced the old tie rod ends with heim joints I had laying around. These didn't have a zerk fitting, I turned the inside 90 deg then drilled and tapped 1/4-28. You can buy these w/ a zerk in the from McMaster-Carr for 10.00
That said, I found (i think) the T7's have a straight bore for the tie rod bolt, others are tapered. I used a big inner tube for a bike to give a little protection from dirt.
I bought a new bucket, then made a SSQA for it, Love it. The cutouts weren't needed, I welded the pieces back in place. The spacing of the lift arms forced me to pull things closer than I liked. I still need to put a 1" stop block at the levers and shorten them because of over lap.
Next was a 9" wide hoe bucket to dig drainage ditches. I cut the mounts off the old bucket( you see it in the new bucket) and will weld on the mounts for the hoe. I'll be using it, to clean ditches. ( I'll get pics using it when it's finished)
I'm a old school manual machinist (I do run a CNC mill at work) If I didn't have a home shop, it would be a lot tougher making stuff.
I finished the hoe ditch bucket. Next is forks and a grapple. ( first picture it's tacked, fully welded all around)
I'm back and forth to use the grapple on the bucket or with the forks.
I think I may make it bolt on or use 2" receivers to mount it, then I could swap between bucket or forks.
Any thoughts?
   / T7 SSQA, 9" hoe bucket and tie rod ends DIY #3
Nice fabrications. Making your machine more versatile. Envying your skills! Keep showing your progress.
I had a few asking about the SSQA I put on myT7. I drew a better version of what I did on my white board.
A added bonus is dimensions for the hoe attachment plate(1/2"). I made some hoe plates, drilling them, then using the big saw at work, cut them out.
It should be 6 5/8 not 6 3/8.
2008 CAT 305C (A53317)
2003 Chevrolet 1500 Silverado Crew Cab Pick-up Truck (A55852)
2003 Chevrolet...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
