Price Check T5C drive pedal spring
/ T5C drive pedal spring #1
chicora1hillbilly
Chicora Pa.
Yanmar 186/Terramite T5/2015 RAM 1500 ecodiesel/Equipment trailer/dump trailer
I have owned my T5C for 8 years and only use it for projects around the place and some jobs for people I know. In the 8 years I have had 2 drive pedal centering springs go bad. A few years ago I purchased 2 thru Terramite and had over $40 in the 2 replacements. Since I am using the last one at this time I would like to get spares but do not want to spend $25 to $30 ea. for them. Do any of you know of a source for similar springs at a reasonable cost? Thanks
/ T5C drive pedal spring #2
The springs are proprietary to Terramite so another source is unlikely. Terramite does not charge a handling fee now show shipping will be cheaper and now there is no minimum order either.
/ T5C drive pedal spring #3
I just got a old terramite and the pedal is not working right same to always be in drive or going backwares i have to take my hand to push up or down to get it to stand still ... is the sprind on the perdel or something else?
/ T5C drive pedal spring #4
Terramite part number 13029 pedal spring. Call parts at 1-304-776-4231 ext 403.
Sure sounds like the spring, it is located behind the petal next to the bearing. The petal is held on by the 2 bolts you can see, lossen them and the petal will slide off. You should see what is left of the old spring, a new spring is placed with the loop over the shaft and a prong on each side of the postion bolt. To adjust the petal leave it loose on the shaft while centering the shaft in the petal then tighten, you will need to fine tune the petal position so all movement stops when you release the petal. Use caughtion as the tractor may try to move during the tuning process.
Brain freeze, its a PEDAL not a petal.
/ T5C drive pedal spring #7
Travis, this is good to hear. I love my terramite, but allways hated buying parts from them because of the high shipping charge's. Glad to hear terramite is getting with the program.
/ T5C drive pedal spring #8
Make your own spring - music wire near the same size. tools - vice, hammer, 3/4 in. round stock to wrap wire around, vase grips, small bore pipe about 2 foot long for a handle to control the wire bending.
it might not look factory made but it does work. only cost about $4.oo, time will depend on skills, took me about 1 hour to bend and install.
good luck all.
2000 LINCOLN TOWNSCAR (A64278)
2000 LINCOLN...
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
