T574 hydraulic filter change
   / T574 hydraulic filter change #1
NewfieTractorNut
Newfoundland, Canada
TYM T574 HST
So i am at the 50 hour mark with the new 574 and in the owners manual it says to change the hydraulic filter. However it does not say i need to change the fluid, so i am wondering if i need to drain said fluid to change the filter or if i pull the filter will it dump all the fluid? Is there be a shut off valve to prevent loss of fluid? Kinda lost at the moment any help is appreciated. Thanks
By the way the tractor is a 2020 tym t574 hst
   / T574 hydraulic filter change #2
You will lose a little fluid, but it shouldn't be much. Just check your levels and top off if needed.
   / T574 hydraulic filter change #5
Newfie, I have the RK37 which is made by TYM and it specifically says to change the fluid and filter at the 50 hour service. I can't imagine that machines made by same manufacturer would have different requirements just because they have different name badges. That's just my opinion......Don
   / T574 hydraulic filter change #6
50 hours you should change hydraulic oil AND filter in that TYM if you want to be really proactive.
TUBELINE TL50LSV LOT NUMBER 119 (A53084)
TUBELINE TL50LSV...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
