T451 Clutch adjustment
   / T451 Clutch adjustment
I figured it out, but the clutch must be shot. At least $2,000 to fix.
   / T451 Clutch adjustment #3
As the disc wears, the fingers on the pressure plate move up, and take the adjustment out of the clutch mechanism. If you wait too long, it gets to the point the clutch never fully engages and the disk gets burned up, and the flywheel, and pressure plate get overheated, and you have to replace the whole mess.
   / T451 Clutch adjustment #4
On the 451 I think the cab has to come off then the tractor is split in 2 half’s. It’s a decent amount of work to replace the clutch. As for adjustment there should be something on the pedal under the floor.
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2021 JOHN DEERE 7R230 LOT NUMBER 208 (A53084)
2021 JOHN DEERE...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
Hay Spear for Tractor (A51573)
Hay Spear for...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
