T450
/ T450 #1
iseki
Calhandriz , Lisboa. Portugal
Iseki TA 357 / Fiat 455 C / TYM T451
New clutch disc with 120 hours !!! It will be possible??? Has anyone had similar problems? IMG_20190504_193346_517.jpeg
/ T450 #2
Wow! Really? That's unlucky! What was the problem? Wear? Burned disc?
/ T450
I bought it two weeks ago, the former owner should rest his foot on the clutch pedal
/ T450 #5
Conseguiu arranjar material para isso? Pelos vistos foram 120 horas a passear com o pé na embraiagem. Até dá pena ver um tractor desses, nesse estado.
/ T450
É verdade , tal foi o aquecimento que o ferodo até se está a desfazer , fiz 3 horas nele e consegui chegar a casa mesmo a conta
/ T450
Há uma oficina aqui perto que colocam forras novas , é lá que vou com o disco na segunda feira
/ T450 #8
Visto que aqueceu muito, é melhor inspecionar bem para ver se a prensa não empenou com o calor ou se as molas não deformaram. Senão nunca fica a 100%.
Some people don’t know how to use a clutch. Should be a really nice T-451 when you get it back together.
/ T450
You can believe Btown, I'll start putting it together today, I hope everything is fine
/ T450
Luckily it was not necessary to take the cabin out as it already happened on my Iseki TA 357
Like new again! Great job. Now we need some videos of this beast :)
Nice job, your tractor does have a T450 on it. In the US the T450 was the open station and the T451 was the cab version. Should give you years of work. That should have a Kubota 2.2L in it. I almost bought one a couple years back. It was repossessed, it was a little banged up and was really cheap. It had like 1300 hours on it. Someone snatched up before I could.
/ T450
Yes, here in Portugal we use T450 for open station and for cabin version. In the US you have Scorpion and other brands that use the same tractor. I have already seen on you tube the T451 is all the same as mine inside the cab and outside .
Yes he as a Kubota 2.2 engine
2016 Ford F-350 XL (A64911)
2016 Ford F-350 XL...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Rhino MDB 130 (A64911)
Front Tank Bracket (A64126)
Front Tank Bracket...
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
Mower King QA 72" Rototiller (A64912)
Mower King QA 72"...
