T300 Battery Draining - Code 17-07
/ T300 Battery Draining - Code 17-07 #1
Drug Man
White Lake, MI
Bobcat T300
I have a T300 and battery keeps draining. I got a new battery and new alternator. Worked for a while and now is draining again. I put it on trickle charge overnight and will work for a couple of days before draining again. Any Ideas?
Also, moving dirt the other day and bucket would not lift or tilt. Light came on and gave me code 17-07 (hydraulic lock valve open circuit). Do you think its a bad solenoid?
/ T300 Battery Draining - Code 17-07 #2
17-07 code could be bad solenoid or loose pin in a connector or broken wire in the harness. Without taking some ohm readings and continuity tests you without just starting to replace parts by guess.
Thanks. I'll try to take some readings. Any idea why the battery keeps draining?
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
Vision 250/50R15 77D Golf Cart Tires (A61166)
Vision 250/50R15...
2025 Western Star Dump Trucks 49X Truck, VIN # 5KKHBWDR7SLVH9248 (A61165)
2025 Western Star...
New/Unused Wolverine 72in Quick Attach Bucket (A61166)
New/Unused...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A62130)
1987 FORD F-350...
2019 Chevrolet Express Box Van, VIN # 1GB0GRFP7K1370206 (A61165)
2019 Chevrolet...
