T273 -what will be next problem?
/ T273 -what will be next problem? #61
Hi Tymdealer,
I got read your reply and I appreciate the input! I, unfortunately, do not have any tractor dealers near me; nor do I feel the need to source out at this point for this particular problem [that has somewhat disappeared once again!].
However, I bought a steering wheel puller today at a local auto parts store. Of course, when I got home, just to check and ensure I bought the right tool it seems the steering wheel is unique to TYM. IE...my standard puller has bolts (metric & sae) along with a pair of L-shaped shafts that are used vice threaded bolts if'n no holes are apparent and guess what? To my dismay, there are no threaded or unthreaded holes inside the steering wheel hole.
All I've got is a 1 & 1/2" wide by approx 1" deep hole with no hold down/clamp locations readily visible?
What am I missing? Do I need a specific type puller or what? I intend to pull my steering wheel, lift off the dash top and replace the hood spring with a thicker/stronger spring. I am convinced that that is all it will take to remedy this problem I've been having.
But -- what is the correct type of puller to buy? Can you enlighten me as to the proper tools I need to acquire? If so, many many thanks your way!!
Once again, I do appreciate the input to help me rectify my problem and I am thankful that there is at least one TYM dealer still alive within the USA.
Bud, I read and heard your input also! That may be a next step for me too; however, it'll need be way further down the road for me. I have checked & re-checked my frame bolts & have had them loosen up on me only the one time? These "Lil Red Beasts" seem to pick individual & personally perplexing problems that they then pounce upon their owners with!
One last request -- has any 273 owner pulled their steeing wheel? If so, what type of puller is required? Am I so blind I just can't see how it's done? If so, envisen me please!!
Thanks to all & hang in there, these problems will eventually work out [I SURELY HOPE!] Greg
/ T273 -what will be next problem? #62
Gregster,
I just walked in the door from troubleshooting a cruise control problem and I had the bottom section of the dash off without taking off the top section (dash cluster) and steering wheel. Just take out all the screws in the black plastic dash housing and you should be able to finagle the bottom section out. It takes a little bit of prying at the tabs (where the screws were) but it can be done without damaging those tabs. Once you get that off, you have a pretty clean view of the hood spring.
/ T273 -what will be next problem? #63
Myyaz233;
Thanks for your reply/input. I had been thinking the same thing, 'cept I'm not ever so lucky! I'd surely break off one of those four tabs, then be in the river - much more deeply. Thanks for your suggestiion and I may end up attempting it.
I've already lost one of the "push-in" rubber bumpers that circle the hood attachment area; and getting replacement parts is like pulling your own teeth! I've previously contacted TYM in Oregon for other desired replacement parts and been told "the ships are in the water - we'll call you when they dock"!! This was months ago. I have no faith in procurement of parts. I only hope I can fabricate or cross-reference desired parts with other makes. IE..Montana.
What I was hoping for -- was that another TYM owner had, in fact, already pulled his own steering wheel and could somewhat guide me through this supposedly simple process.
All I'm asking for is some info on which/what type of puller is required? If an automotive type - I bought one - and it doesn't appear to be the correct tool? Am I misunderstanding how to operate this simple device? If so, please enlighten me!
Thanks for listening.....Greg
/ T273 -what will be next problem? #64
I recently pulled the steering wheel on a T500 and used a regular 3 arm puller. It came off very easy.
/ T273 -what will be next problem? #65
Myyaz233;
I had some spare time so I decided to pull my steering wheel. You are correct a normal puller does not seem to do the trick. The claws can't seem to get far enough underneath so they end up trying to tear the rubber. See the last picture for a good laugh but that is how I got it pulled. Not pretty but it worked. The key is even pressure on three sides. I did spray PB blaster in there at noon over my lunch today and pulled it this evening.
sorry, but this is probably not the solution you were looking for.
/ T273 -what will be next problem? #66
Myyaz33,
Thanks for showing me that it can be done by homeowner! I hadn't thought of that method, but it worked and I'm gonna hafta try it. Just can't understand why it's designed so difficult to be pulled. Even shop mechanics must shake there heads over this goofy mess.
If you look at pic 1 and 3, I wonder why the holes are on the underside of the hub? Those two holes (if threaded) are exactly what is needed to be seen from the top-side as to pull it properly?! I believe that was pic 2, mine is the same -- no holes or slots inside the round rim to catch any bite onto!?That's how the style of puller I bought is supposed to do so.
I'll have to go get a three jawed puller also; it wasn't my first choice because I saw that there wasn't enough room to get the jaws underneath the wheel! It's about an 1/8" space between wheel and dash top; looks like yours is still same style as mine.
Thanks, Greg
/ T273 -what will be next problem? #67
I had some warranty work done in my driveway that involved pulling the steering wheel. I think the guy just pulled it off without tools. Of course it was pretty new at the time and now might be rusted on, don't know. Good luck.
/ T273 -what will be next problem? #68
Add to the list of problems.
285 hours
Weld in seat broke.
Hood popping open.
The problem with the hood popping open is not with the latch. It is caused by the chassis twisting. Keeping all the bolts both front and back tight helps but they seem to get back loose with a few hours of loader use. The tractor should have some bracing to tie the loader to the back of the tractor. Look at some other brands they have this. That would solve the twisting. I am going to cut some channel or angle and make some braces that will bolt in or weld to the frame for support when I have time. All the twisting of the chassis will soon cause something else to break.
You are so rite, my front frame just snapped!!! It broke through the FEL mounting holes just behind the fuel filter.I guess I will see what TYM says tomorrow.Wish me luck:confused2:
/ T273 -what will be next problem? #69
Greg,
I have personally pulled many steering wheels off of 233/273, and have never had a problem only tool i have ever used is a hammer to tap up on the bottom of it. Normally just remove nut and pull it off.
/ T273 -what will be next problem? #70
Greg: Use a brass rod about 1 1/2 in in diameter 10 to 12 inches long. Remove the nut untill it is flush with the threads then have a partner pull up on the steering wheel keeping constant pressure on it. Place the brass rod against the flush nut and strike with a heavy hammer until the steering wheel pops up. This is the way we removed most flywheels from small engines in the shop i worked at, and I used this method to remove my steering wheel. When you put back together use never sieze on the splined shaft so it doesnt rust together. The brass is softer than the steel so it wont hurt the threads.
/ T273 -what will be next problem? #71
Resurrecting an old post here but this saved me today. My instrument gauge died on Sunday while working out where I had no tools and worse, no fuel available for miles. I was getting panicked at the end of the day that I was going to run out of fuel. Made it home though and was able to pull the panel out today once I got the **** steering wheel off! I didn't have anyone to help so I used a puller to get some upward pressure without ruining the plastic and then used a hammer on top of the puller. A few hits and the steering wheel popped off. Anti seize on the splines before I put it back together. I couldn't find anything wrong with the wiring so I put it back on the panel and turned the key on and it's working again. No idea what happened to it and the connectors didn't feel loose when I removed them.
Does anyone know if you can still get parts like a new panel for a 293hst if necessary?
/ T273 -what will be next problem? #72
myyaz33, It's been about ten years since I first asked about this and I've "finally" gotten around to pulling mine off. You were/are absolutely correct - it's a real pita to get off!! What should have been about a 15 - 20 minute job took almost two hours! I farted around with my 3 jaw puller, screwdrivers, and pry bars for spacers and finally got enough steady pressure on it that with a BFH to the top of the puller it popped up. It'll never be as hard to come off again as I am going to "liberally" coat the mating surfaces with anti-seize now that it's off and before it goes back on.
My hazard light switch has stopped working and I wanted to use this "off from work" time to finally get around to fixing them - not that I even use the hazard lights but my fuse is good so it has to be a poor switch contact from all the times I was pressure washing the beast when it was new new - to keep it looking new - and not like an actual 'often used' tractor really looks! You know, new owner of a brand new machine - at first wants to keep everything as new! But soon enough reality sets in and jobs come before looks! Besides, I'd like to see/check on what's all behind the cluster/dash. In fact several other contacts are being fussy when asked to be used; horn, turn lights, etc., etc., and there is the main hydraulic feed hose that runs behind the cluster that I'd like to check/ensure it's now becoming chaffed or anything.
My plan is to clean up all electrical contacts, douse with dielectric grease, and reassemble. If I don't happen to break any electrical switches unplugging them, it should be a fairly simple clean up. But, as you know - simple things often turn into complicated ones! Ha! I hope it stays simple - getting the darn steering wheel off was hard enough. But I originally asked for anyone who'd removed their wheel - you replied with actual photos of the process, and I wanted to let you know I'd finally gotten around to following/taking/using your advice. And it was entirely accurate advice!! Thanks again, Greg
/ T273 -what will be next problem? #73
Good to hear from you Greg. Glad to hear you are making good use of this crazy period in time to cross some things off the todo list. We are still pretty low in COVID cases out here in Nebraska, but expect to start seeing a few this week in our area. Still going to work every day for now. My tractor hours have been down a lot in the last 2 years but this spring I have plenty of things lined up for it. I really have gotten a lot out of that little tractor and am so glad I have it. Also now have a Bobcat S185 which makes certain tasks much quicker.
Hope all is well with you and your loved ones and our TBN friends.
Marty
/ T273 -what will be next problem? #74
Hey Marty!!! Sure good to hear from you again - Sorry it took me ten years to re-refer to the post I asked 'you for advice on' in the first place! But, yeah I've suddenly had the "extra" time to get around to things that are not immediate concerns. I am going to take the time to 'uncover' aspects of the TYM that are hidden from sight.
Like the fact that my manual shows 3 relays down under the lower dash cover? But not accessible from the engine side?!! If they are "in fact" there,,,-what a CRAZY place to put them??!! Unless that is a direct excuse for a TYM owner to "have" to take his tractor to a dealer for an "enormous" repair bill cost as the labor at a shop would be HUGH! To replace a $10.00 relay. Ha! If so, they were devious in their thoughts.
At any rate, I just wanted you to know you were absolutely correct in the pita it is to remove the steering wheel! I noticed once mine was off that there are 2 drilled/tapped holes - that I "assume" are for a wheel remover - located on the (underneath) side!! How dumb is that! Probably put together at the factory upside down and NO one noticed!! If I discover any other nuances I'll be sure to post. I do love my tractor, but it's sure got some quirky things that pop up with it. As do all others I'm sure.
I'm not gonna be a COVID nanny, but you should be real careful at work my friend - this thing is nasty, thirsty for victims, and very SNEAKY in its approach. It seems to be doubling in days! Shaking hands "USED" to be a way of life...not so any longer. 2 weeks before symptoms even appear, so no can tell where/when/whom you might catch it from. Gotta work if you can; I agree and I even miss working considerably - but I like living even better!
Stay safe. Greg
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A59906)
2006 MAC TRI AXLE...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2006 Ford E-350 Cargo Van (A61568)
2006 Ford E-350...
