Gregster613
- Joined
- Apr 19, 2009
- Messages
- 1,047
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi Tymdealer,
I got read your reply and I appreciate the input! I, unfortunately, do not have any tractor dealers near me; nor do I feel the need to source out at this point for this particular problem [that has somewhat disappeared once again!].
However, I bought a steering wheel puller today at a local auto parts store. Of course, when I got home, just to check and ensure I bought the right tool it seems the steering wheel is unique to TYM. IE...my standard puller has bolts (metric & sae) along with a pair of L-shaped shafts that are used vice threaded bolts if'n no holes are apparent and guess what? To my dismay, there are no threaded or unthreaded holes inside the steering wheel hole.
All I've got is a 1 & 1/2" wide by approx 1" deep hole with no hold down/clamp locations readily visible?
What am I missing? Do I need a specific type puller or what? I intend to pull my steering wheel, lift off the dash top and replace the hood spring with a thicker/stronger spring. I am convinced that that is all it will take to remedy this problem I've been having.
But -- what is the correct type of puller to buy? Can you enlighten me as to the proper tools I need to acquire? If so, many many thanks your way!!
Once again, I do appreciate the input to help me rectify my problem and I am thankful that there is at least one TYM dealer still alive within the USA.
Bud, I read and heard your input also! That may be a next step for me too; however, it'll need be way further down the road for me. I have checked & re-checked my frame bolts & have had them loosen up on me only the one time? These "Lil Red Beasts" seem to pick individual & personally perplexing problems that they then pounce upon their owners with!
One last request -- has any 273 owner pulled their steeing wheel? If so, what type of puller is required? Am I so blind I just can't see how it's done? If so, envisen me please!!
Thanks to all & hang in there, these problems will eventually work out [I SURELY HOPE!] Greg
