T273 - Another broken driveshaft/input shaft
   / T273 - Another broken driveshaft/input shaft #31
So here is the telescoping version on the Mahindra eMax 25.
$500+ for the whole thing. It might fit but it also comes with the fan.
I may just order a TYM shaft.
The TYM shaft is around $230 US Don't know about shipping to Canada though.
   / T273 - Another broken driveshaft/input shaft #32
A TYM shaft is on its way from another part of the country. There are no dealers near here. $250
   / T273 - Another broken driveshaft/input shaft #33
Be sure to cut the hole if the floorboard doesn't already have it as mentioned by Bud. A big hole saw (like 4 inches or more) will do.
   / T273 - Another broken driveshaft/input shaft #34
I just turned over 500 hours on my T273 and literally within the next hour I experienced what I am almost certain is the driveshaft problem described here. I was brush hogging, stopped, backed up, and when I stepped down on the pedal to go forward it made the sound of grinding the edge of gears (or shaft splines) and will not move forward or backward. I immediately shut it down and looked for broken parts or hydraulic leaks and found neither. I started it back up and all the hydraulics function normally, but the metal to metal sound of barely trying to put a transmission in gear with the clutch out is constant, so I quickly shut it back off, towed it to my shop, and started searching this forum for answers.
If I had only known, I sure would've replaced it before it happened. I have researched online and have only found the driveshaft part #13182102100GB at ET-Parts for $618.73 + 36.20 tax + 14.95 shipping via UPS Ground or USPS. Total $669.88!
Since the last previous post was Oct 2015, and the price then was "around $230", I will assume I will be paying the new Bidenflation price of 3 times that? Any help of a source to find one for any less $$$?
I will be contacting our local TYM and Mahindra dealers here in Springfield, MO tomorrow morning to see if they can, 1- Get the part, and 2- Save me any money. Good grief! TYM really should notify tractor owners if they have a tractor with a known issue, even if they won't warranty the repair. I would much prefer to know and perform the preventative repair and possibly save additional issues that may well cost more to fix than the tractor is worth.
   / T273 - Another broken driveshaft/input shaft #35
The manuals Operators/Service/Parts for the T233 and T273, are readily avaialble if you search for them.
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
207010 (A55853)
207010 (A55853)
Cushman Golf Cart (A55853)
Cushman Golf Cart...
John Deere 650K (A53314)
John Deere 650K...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A55851)
Generac Yanmar...
2016 BOBCAT T590 SKID STEER (A52706)
2016 BOBCAT T590...
