T190 damage while installing chain box?
/ T190 damage while installing chain box? #1
JRP
Platinum Member
South Texas
Kubota M6800
While installing a chain box I drilled two holes in the side and tapped them 3/8-16. I thought I would be drilling into nothing, but the drill hit something. What is behind this area?
/ T190 damage while installing chain box? #2
On skid steers, it is the chain case with the drive chains from the hyd. motor in the middle to each wheel hub. Usually there is a few inches of oil in the bottom for the chains to pick up lube. With your ctl with 1 drive motor in the back, I would have guessed that you would be fine dirlling/tapping also. If everything still works and no fluids are leaking or disapearing, run it. Check with your dealer to be sure, I've had Case, NH, JD & Gehl SS's but never a BC. Or ask at Skid Steers
/ T190 damage while installing chain box? #3
The main control module (computer) is in that area, bolted to inside of the frame.
Well, no problems yet.
/ T190 damage while installing chain box? #6
If no problem by now you should be OK. That controller box is about 1 &1/4" thick with circuit board mounted to inward side, and back of it is filled with epoxy to seal it. My have just bumped up against the back side of it.
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2004 International 7400 C&C 017797 (A62613)
2004 International...
TAKEUCHI TB230 EXCAVATOR (A64279)
TAKEUCHI TB230...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
