T190 damage while installing chain box?
/ T190 damage while installing chain box? #1
JRP
South Texas
Kubota M6800
While installing a chain box I drilled two holes in the side and tapped them 3/8-16. I thought I would be drilling into nothing, but the drill hit something. What is behind this area?
/ T190 damage while installing chain box? #2
On skid steers, it is the chain case with the drive chains from the hyd. motor in the middle to each wheel hub. Usually there is a few inches of oil in the bottom for the chains to pick up lube. With your ctl with 1 drive motor in the back, I would have guessed that you would be fine dirlling/tapping also. If everything still works and no fluids are leaking or disapearing, run it. Check with your dealer to be sure, I've had Case, NH, JD & Gehl SS's but never a BC. Or ask at Skid Steers
/ T190 damage while installing chain box? #3
The main control module (computer) is in that area, bolted to inside of the frame.
Well, no problems yet.
/ T190 damage while installing chain box? #6
If no problem by now you should be OK. That controller box is about 1 &1/4" thick with circuit board mounted to inward side, and back of it is filled with epoxy to seal it. My have just bumped up against the back side of it.
AMVAC SMART BOX PARTS (A63291)
AMVAC SMART BOX...
CASE INTERNATIONAL 6088 RWD COMBINE (A63291)
CASE INTERNATIONAL...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
KMC 3386 (A64119)
KMC 3386 (A64119)
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
