t1-11 siding
/ t1-11 siding #21
Ditto that Eddie, also really no need to. I wash my vinyl sided house with 1/3 clorox and 2/3 water plus one-half cup dawn in a one gallon hand sprayer. Wet the surface, spray the siding bottom up, wait a few, then rinse down with hose. Stubborn stains I respray and brush with a vinyl siding brush on a pole extender.
Siding sparkles like new when done, do it every other year since I an surrounded by several large fields that generate lots of dust in dry weather.
Watched a guy pressure wash a house once, the homeowner took all kinds of water in the house and up under the moldings. Very few things needs that kind of pressure to be cleaned properly.
/ t1-11 siding #22
In CA we used stucco on our extra garage and tractor storage. I know it isn't good for snow areas ( it will absorb moisture and then freeze/crack) or in wet areas like Seattle as it will mold but in dry Southwest areas it works. They use 2x4 or 2x6, foam insulation, wire, a scratch coat, then a brown coat, and finally a top coat, then paint.
/ t1-11 siding
ended up using the pre primed wall board 4 by 8 sheets,comes grey in color,wnet up great and is sealed up good....I hope. Wont be applying paint for a few months. I will post some pics when we get closer
thanks
