T post removal
/ T post removal #1
drajj5
North GA
Mahindra 28, Bolens G14 repower
So, I need to hear some tips tricks to puling t post out of the ground. These have been set for years, they are the heavy gauge with (nubs on one side). I "don't" own the high dollar T Post puller, and use the wife and a bucket curl to extract the pesky suckers. I just know that there is someone who has a fantastic and easier way to do this.... So who has that trick ?
/ T post removal #2
I used to use a fabricated device. Mostly it's a chain wrapped around the post, and a stand the right height to pry the chain and the post out. It always worked.
A couple of years ago, I decided to buy an actual "T post puller". It's faster, and easy to use.
Search Amazon, or E-bay for examples. $50-$90
/ T post removal #3
Do a search here, there was a lot of previous posts on this subject. Me, I use chain and wife on tractor also. Fast and easy.
what I did do though is I made a small loop with some insulated steel cable. I slip that over post and then use hook on chain to grab loop. As wife raises bucket, loop catches nub and pulls out post.
/ T post removal #4
Tractor with boom pole or bucket and a few half hitches and it will grab and pull it out
/ T post removal #5
Chain and either the tractor bucket or the hi-lift jack off the jeep
/ T post removal #6
I also just use chain and the fel. 3 or so wraps around, then hang the hook on the working end of the chain and it binds up nicely.
/ T post removal #7
A piece of square tubing bolted to the side of your bucket slide it over the post tilt bucket back lift up and out
/ T post removal #8
chain wrapped works really well...when you have the other end attached to a shackle on a FEL.
/ T post removal #9
This. Works well and is fast.
/ T post removal #12
I made one. Works good.
Two flat metal plates or angle . I used 1 1/2 angle I had. Three 3/8 cross bolts for about 1 1/2 inch between plates. and about 2 inches between bolts
Drop either end over the post and pull up or jack up on the 3rd bolt.
Bruce
/ T post removal #13
I have a Speeco t-post puller plate that works good with the loader and chain. Mostly I use it with the high-lift jack though.
https://www.amazon.com/SpeeCo-S16110400-Removed-Handyman-Different/dp/B0042U6DBY
I also use the Speeco puller except I got mine at TSC for $13.99. Coupled it to a short piece of chain to my SSQA receiver hitch plate. I just have to get off the tractor to hook it up to each post if I am by myself. With 2 people pulling posts goes fast.
/ T post removal #14
You can use a piece of wood or steel about 3-4 feet long. Push the t-post away from the nubs, wedge the board in there and pull back. Repeat until the post is loose. Still not nearly as easy as a puller though. Not sure what "high dollar" means to you, but T post puller's that work great are less than $100. It's worth it if you're gonna pull more than a few.
/ T post removal
Interesting, that you questioned "High dollar", it was to reach out to some ingenious fellow who has used some sort of household item that they used to pull them (without cost).... I am not sure if you saw the show MacGyver but that guy used duck-tape and a piece of string to make a bomb. I know there is more than one way to string a cat, but cannot for the life of me think of any other ingenious idea that would keep me from doing it in the same fashions outlined in the post(s) above.
/ T post removal #16
I paid $50 for a T post puller from Tractor supply to take out a bunch of T posts. I tried using my loader to pull them with a chain, but they always bend, and it takes too long getting on and off f the tractor when doing it by yourself. If you have a helper, and you don't want to use the T posts again, then the tractor would be faster.
I just did them a few at a time after work. It makes a huge difference if the ground has some moisture in it. Dry ground and they don't come out at all. Couple of rains later, and they come out easy!!!!!
/ T post removal #17
I usually just wiggle the posts back and forth then pull. However, I've used those post pullers and they're pretty sweet. So, if you have 10 posts, just wiggle them or get them out however it works. If you have 1000, then get the post puller.
/ T post removal #18
That's the one I got too, from TSC.
/ T post removal #19
My experience is that when the ground is soft, it's a lot faster to walk from T post to T post, and pull them out with the T Post Puller, then it is to drive the tractor to the post, get off the tractor and attach the chain, then pull the post, untie the chain, and then get back on the tractor and drive to the next T post.
So far, I haven't bent a single T post using the manual puller. I think I've bent every one that I pulled with my loader.
/ T post removal #20
If the ground is really soft, I use a wooden plank underneath the puller's foot, so that it doesn't sink into the ground.
2009 FORD CROWN VICTORIA (A66091)
2009 FORD CROWN...
CATERPILLAR 920 WHEEL LOADER (A65056)
CATERPILLAR 920...
PALLET OF HEAVYEQUIPMENT PUMP PARTS (A68842)
PALLET OF...
2013 WACKER NEUSON HF 690 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2013 WACKER NEUSON...
2017 KAUFMAN T/A CAR HAULER (A67714)
2017 KAUFMAN T/A...
2006 FORD E450 UTILITY TRUCK (A66091)
2006 FORD E450...
