System Bleeding?
   / System Bleeding? #1
prof fate
Platinum Member
beaver pa
kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
My Hydraulic fluid got low (not a lot..still on the dipstick) and the bucket tilt cylinders got wonky, so I filled it and it's 95% good...the bucket tilt seem a tad off though, like they need bled.
I've put the bucket up, and down, and worked it all around (not quite the hokey pokey though).
When I set the bucket down it seems to be less than solid. If I move the lever it's got all it's power, but it's like it's got air in the system and moves when it used to sit/hit solid without me having to move the lever.
Kioti CK3510HST with 200 hours on it.
   / System Bleeding? #2
Cycling boom/bucket several times should eliminate any air in FEL hyd circuits UNLESS air is being sucked into tractor hyd circuit which would need to be corrected.
   / System Bleeding?
that was my understanding. i have one line that weeps some..i'll see if I can tighten it or what's leaking. it's under warranty but i hate to burn up my free service call on a weepy hose.
   / System Bleeding? #4
If fluid can get out, air can get in.
6' ROTARY MOWER (A51247)
6' ROTARY MOWER...
2003 JOHN DEERE 350D OFF ROAD DUMP TRUCK (A51246)
2003 JOHN DEERE...
UNUSED WOLVERINE PT-16-01C UNIVERSAL ADAPTER (A51248)
UNUSED WOLVERINE...
UNUSED INDUSTRIAS AMERICA 10F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
(INOP) MURRAY BOGGIN MOWER TRACTOR (A51247)
(INOP) MURRAY...
