Synchro Shuttle grinds a little into forward
/ Synchro Shuttle grinds a little into forward #1
mohrt
seymour, wi
2003 Mahindra 6000 4WD
Anyone know if there is an adjustment for this. It is not too bad. It always goes in, but it should be smooth. Reverse is fine. 2003 Mahindra 6000 4WD
Thanks, matt
/ Synchro Shuttle grinds a little into forward #2
My synchro shuttle sometimes used to growl at me if I didn't come to a complete stop before throwing the reverser lever. Now I'm in the habbit of stomping on the brake as I reach for the lever. No more growling/grinding, just happy tractor.
Yes, I have tried that as well. Even when I am stopped, sometimes it grinds a little into forward. Reverse, never. It never used to do that. I am hoping there is an adjustment or fix without digging into things too deeply, but not sure.
/ Synchro Shuttle grinds a little into forward #4
The only adjustments I've ever seen on a 6000 are linkage related. there are some links and toggles under the sheet metal panel below the steering wheel. You might check them if the lever travel feels restricted or does not fully engage the shuttle, but if the synchronizer simply feels rough and/or hard to engage, I doubt that any adjustment will cure it. Once you get it locked in, does it perform OK in forward, or does it ever fail to drive and cause you to shift back to neutral and try again? Has it ever jumped out of forward while traveling?
Yes, once in it works perfectly and has never jumped out.
/ Synchro Shuttle grinds a little into forward #6
If it's not jumping out of gear, and the lever travel feels like the distances are about the same as always, I believe you're resigned to live with it this way unless it gets worse. Should you decide at some point to replace the syncronizer, I suggest you research the process before attempting it on you own. I replaced that same part in a 6000 last spring, believe me, there are a lot of parts on the floor before the syncro is out and on the table.
Sounds good. I'll check the linkage to make sure it is balanced and otherwise will let it be and keep an eye on it. Thanks for the advice. matt
2013 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2013 VOLVO VNL 6X4...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2025 JMR Tree Boom Skid Steer Attachment (A61572)
2025 JMR Tree Boom...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2015 John Deere 8295R (A64119)
2015 John Deere...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
