SX3100 vs Ex3200
/ SX3100 vs Ex3200 #1
gj1999
I'm upgrading my sc2400 to either a sx3100 or ex3200. I'm really leaning to the sx3100 because of the ease to add the mower deck and I like the forward snowblower. I'm curious if anybody has had any negative issues with the sx3100.
Glenn
/ SX3100 vs Ex3200 #2
It's very difficult to find much info on these tractors. I've done alot of research and was in the same place you were a few weeks ago. Either tractor is very nice. The SX is the newer design with a mid mount PTO standard. For me, the SX frame was too small and reminded me of a lawn mower. The EX3200 is an older design with a 3 speed tranny. I personally like the cockpit of the EX better...some may find it cramped. I just bought an EX32 and its getting delivered this SUnday.
They are both very good tractors. If you are interested, I know where there's a new SX with loader for 13.6. PM me if you want the info.
/ SX3100 vs Ex3200 #3
JFCCAC did you just call my tractor a lawn mower:hissyfit:.i guess you did. Well gj1999 i have just purcjased a new SX3100 a month ago. I have not used it much yet so i can't comment to much on it. I am very happy with my purchase. I did get mine with a loader and MMM. A great set up for taking the MMM off. My reason for going with the sx3100 was the fact its alittle smaller versus the ex3200 and alittle lighter. One thing i am worried about that i will find out in the spring is if it is to heavy for mowing the lawn. I have tried it alittle this fall and it seemed ok weight wise. Just hope i don't tear up the lawn with it, time will tell. So just keep that in mind if your thinking of using it to cut your lawn. i figured its in the area of 2500lbs with loader and mmm. Good luck with your search. I don't think you can go wrong with any choice you make. And by the way i believe the sx3100 has more break out force than the ex3200 just i side note for those calling my tractor a lawn mower.:yell:. LOL have fun shopping.
/ SX3100 vs Ex3200 #4
Builder,
I guess I did! It does have a MMM...so it is a lawn mower..is it not?
I looked at the SX and the EX. Its all in your preference. I like the EX better as it looks beefier and is a bigger overall frame. It's (the EX) also an older design as compared to the SX.
Builder...I'm not sure what specs you are looking at but the brochure I have in front of me shows breakout for the SX at 2090 and the EX at 2500 (at the pins).
Either tractor is great...
JC
/ SX3100 vs Ex3200 #5
I had an EX2900, basically the same as an EX3200. I really liked it, but have no experience with the SX models.
/ SX3100 vs Ex3200 #6
jfccac, your right the EX has more break out force, the SX has more lift capacity. i would say pretty impressive for my "lawm mower":hissyfit: to have more lift capacity over the EX. I don't get that one with the EX being a heavier unit. You are right both units would be great. I did forget to mention that when you remove the mower deck your ground clearence is cut down to about 6-7" due to the rear mounts for the deck. They could be removed if needed but not that quick.Hail to the machine that can lift more !!!!:cool2:
/ SX3100 vs Ex3200
My main uses are mowing, landscaping, and orchard cleanup. I talked to the dealer and am waiting to see what he can give me for my sc2400, MMM, loaded and SB45. I decided to get the sx3100, it fits my needs more and is almost identical to the Jd2720, so parts aren't an issue. I wouldn't mind a JD, but the price is too steep. I looked at the specs and its a trade off and you can put a MMM on the ex3200, I saw a 60" deck on one in Frederick, MD. I'm sure if you call the dealer, they will sell you one.
/ SX3100 vs Ex3200 #8
I love my SX3100, the fel, and mmm are easy on, easy off. I leave the fel off when I mow, I haven't had any problems with turf damage.
/ SX3100 vs Ex3200 #9
JFCCAC you obviously limited knowledge of tractor ownership if you are referring to the SX as a "lawn mower" . I own both the EX 3200 and the SX 3100 and both are excellent machines. This is only this country girl's opinion but I think my SX is more versatile.
/ SX3100 vs Ex3200 #10
pretty interesting first post....tractor chic. You may want to read what you typed before formally posting...as while I may have limited tractor knowledge, it appears your grasp of the English language leaves a bit to be desired
so..do explain what 'versatile' means in your world.
I'm not dissing either machine...as a matter of fact, my brother in law bought an SX with a FEL and a MMM...based on a push (recommendation) from me.
I like the EX better...for what I want to do with it. Many like the SX for their intended needs. Either one is great....as long as it's black and yellow.
/ SX3100 vs Ex3200 #13
as expected...another productive response.
I was under the impression that this forum is intended to share and learn.
I've been researching tractors for 6 months prior to buying and I picked the right tractor for me. I looked at any brands and models..including the SX. For my needs, it is too small and it does remind me of a lawn mower. If that insults you, oh well.
I paid 12,400 for a brand new tractor loader...out the door. I got a smoking deal on a tractor that is exactly what I want.
Enjoy your tractors...whichever CCY model you choose.
/ SX3100 vs Ex3200 #14
Share and learn, yes. Antagonize and belittle, no. Both of you need a time out.
I looked at both models and the Ex suited me better. The SX is a great unit, almost identical in specs, but some of the biggies was the much smaller cooling system capacity, non-foldable ROPS, smaller tires, and more importantly only two trans ranges. The latter put the Ex out in front. Having the mid-range makes all the difference in the world when working it.
See for yourself:
Yanmar Sx3100 vs Yanmar Ex3200 in Tractors
/ SX3100 vs Ex3200 #15
The SX does have foldable rops atleast mine does. I can't comment on the Ex model as i have never seen one. I guess the 3 range hydro would be nice but i don't know any different. With the 32 horses this baby spins the wheels in low or high. I am just glad i finally purchased a tractor. Hey does the Ex have arm rest?
I must say one might think they don't need them but boy does it make it nice and comfortable.
/ SX3100 vs Ex3200 #16
Hey does the Ex have arm rest? I must say one might think they don't need them but boy does it make it nice and comfortable.
No arm rest. I don't think I would want them due to the fact I'm never in the seat for long periods. My lawn tractor has them though! That's important, you know!
/ SX3100 vs Ex3200 #17
Hey, Yanmar EX3200 owners, do all of you have the R-4 industrial tires? I know there are other threads here regarding R-4 vs R-1 tires, but it seems that all the tractors at the dealer have R-4s. I found a good deal on an EX3200 and am planning on buying it tomorrow, but I'm slightly concerned about the tires. My Ford New Holland that I'm selling tomorrow has the Ag tires on it and I love them. I use my tractor for a variety of things; post hole digging, moving piles of stone dust, brush hogging, pushing my horses' crap pile back, and plowing my driveway with my back blade (not tilling any fields or anything). Will the R-4s be okay? I'm having them filled, which may help.
/ SX3100 vs Ex3200 #18
I've never had a problem with the R4s except in really deep snow. Then I should be using chains, but that is another story. If you go in deep mud all the time or really sloppy ground, then the Ags would be better. But, I've never been stuck in muddy or soft ground yet. Having the locking diff comes in handy, too! Good luck with the new EX. I love mine!
/ SX3100 vs Ex3200 #19
Happy with R4s, don't know the difference though. They got the tractor out of mud over the top of the front ax.
2005 INGERSOLL-RAND WL-350 WHEEL LOADER (A62129)
2005...
2009 Chevrolet Silverado 2500 (A61568)
2009 Chevrolet...
2022 Behnke Trailer (A60352)
2022 Behnke...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
