Tires Switching from R4 tires to R1 Ag tires
   / Switching from R4 tires to R1 Ag tires #1
npaden
Platinum Member
Lubbock, Texas
2011 LS U5030C
Okay,
The front tires on my new to me L4200 GST are a little on the worn side. I could probably get another year or two out of them but I'm kind of wanting to go ahead and get some new ones on there.
The R4's on it are 10 X 16.5. It has R4 17.5L X 24 on the rear. The parts manual calls for 8.3 X 16 and 14.9 X 24 R1 tires. The R4's on the rear probably have close to 50% tread left. Reading up on 4wd tractors it sounds like the fronts wear much quicker than the rears.
Can I put 8.3 X 16 R1's on the front and leave the 17.5L X 24's on the rear? Do I need to replace all 4 tires if I want to go to ag tread? Do I have to replace the rims if I switch from R4 to R1 tires?
If so I might just buy 2 new R4 tires for the front and wait 10 years until I need new rear tires.
Thanks, Nathan
   / Switching from R4 tires to R1 Ag tires #2
You might want to read this thread on lag times:
lag
and this information from TractorSmart:
Tractor Smart
Just some overall light reading there. /forums/images/graemlins/wink.gif
So it sounds like I probably have a lag situation on my tires for sure as the fronts are nearly worn out and were probably small to begin with.
I guess I need to find out what my wheels are also.
   / Switching from R4 tires to R1 Ag tires #4
You will probably need new front rims. R4's and Turf/R3 tires use a wider rim for the wider tires; R1's are typically narrower.
On the back, you might be able to find an R1 to fit you rim. The trick is to look at the the overall diamter and rolling radius of the tire. If you find one that matches you're ok. If not, you'll have lead/lag issues which can affect the drivetrain.
The same issue applies to just changing out the fronts, while continuing to run the rear R4's. Make sure the R1 you put on the fron has the correct diameter/rolling radius.
All the manufacturers have this data. The Goodyear site has lots of good data sheets...
   / Switching from R4 tires to R1 Ag tires #5
Hi again Nathan:
Four years ago I removed my factory AG tires and rims. Replaced them with oversized turf and wide wheels /forums/images/graemlins/cool.gif. See attached. You could never get me to switch back to those smaller AG tires. MUCY nicer ride with big tires. Never have I had a traction problem…
If you were closer I would let you try the AG wheel and tires, but I am fairly sure you would not like them. I do not have a picture of my L4200 with the AGs on it. KennyV.
Sounds like the way to go will be just putting on a new set of R4 tires on the front for now. I just called one of the local tire dealers and they have a YKS brand 10 x 16.5 R4 8 ply tire for $98.42 which seems like a pretty good deal. Another shop had a 10 ply Nanking for $100. They also had an 8 ply Michellin for $240/tire!
Never heard of YKS or Nanking before though....
   / Switching from R4 tires to R1 Ag tires #7
I have Titan's on the front, Goodyears on the back. Titan's seem reasonably priced.
Never heard of the tires you mention; Chinese or Korean imports?
   / Switching from R4 tires to R1 Ag tires #8
</font><font color="blue" class="small">( All the manufacturers have this data. The Goodyear site has lots of good data sheets... )</font>
Not anymore. Goodyear sold their ag tire division to Titan.
2022 Horizon (A55973)
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
