Swisher Rough cut 52 only cutting one side
   / Swisher Rough cut 52 only cutting one side
Pushing the mower was a great test. From your original post, the right side cut well, the left side cut poorly. Correct? This makes sense for a CW cutter.
A few things come to mind. Like the above comment, low tip speed seems very possible. 17 hp on a 52" rough cutter is light anyway... especially on gas powered machine. Diesel is capable of way more torque. Does your mower pull down under load? Do you know the published tip speed? If not, we could calculate if you report the sheave diameters.
If tip speed is sufficient and it's not bogging down, a shallow deck shell would cause a mower to behave this way too. Rotary cutters can process large volumes of grass because they have deep deck shells. Too shallow and they stop processing (or slowing to a crawl like you described.) This is the mower's DNA. Use a tape measure under the mower and determine the depth from the blade cutting plane to the top of the deck chamber. Measure your neighbor's DR too (that cuts well). Much difference?
Hang is there... we'll get this figured out!
ok thanks for all the help.
Like you I am on snow watch now since we are in Vermont.
I don't know what the tip speed is - I can ask Swisher and see if they will tell me...
I think the deck is pretty deep but I don't have measurements. When I am near it again I will measure. It will be a while since it is at a seasonal camp and this is not the season I can get to it :(
I know nothing about your unit but it sounds like the blades are going up
and not cutting or something is jamming the blades from spreading out.
Can you put the cutter on its side and turn the blades to ee if they are
running the same on both sides?
willy
Thanks Willy
We have verified that the blades are swinging all the way out and they are pretty tight and don't move very much vertically.
2012 Ford Fusion (A56859)
2012 Ford Fusion...
1250 (A58374)
1250 (A58374)
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
23ft x 22ft Double Garage All Metal Building (New/Unused) (A59225)
23ft x 22ft Double...
2025 SDLANCH TRAILED CRUSHER (A58214)
2025 SDLANCH...
2017 CATERPILLAR 304E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
