Swinging drawbar
   / Swinging drawbar
Looks like the best option is to buy a cat. 1 cross drawbar from TSC and take it to a local machine shop to have the lift pins cut off and 3/16" shaved from each side. That'll be $22 for the bar plus the machining cost. Then I think I will paint it hunter orange. /forums/images/graemlins/wink.gif
   / Swinging drawbar #14
What is a swinging drawbar anyhow? Anybody got a picture?
   / Swinging drawbar #15
Norm, the swinging drawbar is the one mounted usually to the bottom of the rear differential and sticking straight out the back for a "trailer hitch". On some but not all tractors, there are pins you can pull and "swing" the drawbar to one side or the other to pull implements off-set behind the tractor. So they're called swinging drawbars even though some don't swing. /forums/images/graemlins/laugh.gif
   / Swinging drawbar
I usually have a grab hook (link) mounted on mine and use it to pull small trees. It's nearly impossible to tip the tractor over because it's attached at the axle (and I have weighted tires).
Now I know why the farmer I worked for as a kid always used cotter pins instead of the clips to hold things to the tractors.
   / Swinging drawbar #18
Thanks guys, had not run into one of those before. My Yanmar has a drawbar, but it doesn't swing.
   / Swinging drawbar
Actually, I'll bet it does swing.... it's probably very similar to the one on my Cub. It's (was /forums/images/graemlins/frown.gif) a bar about 20 inches long with three holes (storage, operating, storage w/ Mid-mount mower).
According to my operating manual, the operating position is fully extended, allowing the bar to swing side-to-side.
   / Swinging drawbar #20
No..........the drawbar on my Yanmar does not swing. It has 2 adjustments..........all the way in and 3-4 inches out from that.
At least on mine /forums/images/graemlins/grin.gif
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
2013 Chevrolet Caprice Sedan (A56859)
2013 Chevrolet...
12' CONTAINER (A52706)
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
