Swinging drawbar
   / Swinging drawbar
Looks like the best option is to buy a cat. 1 cross drawbar from TSC and take it to a local machine shop to have the lift pins cut off and 3/16" shaved from each side. That'll be $22 for the bar plus the machining cost. Then I think I will paint it hunter orange. /forums/images/graemlins/wink.gif
   / Swinging drawbar #14
What is a swinging drawbar anyhow? Anybody got a picture?
   / Swinging drawbar #15
Norm, the swinging drawbar is the one mounted usually to the bottom of the rear differential and sticking straight out the back for a "trailer hitch". On some but not all tractors, there are pins you can pull and "swing" the drawbar to one side or the other to pull implements off-set behind the tractor. So they're called swinging drawbars even though some don't swing. /forums/images/graemlins/laugh.gif
   / Swinging drawbar
I usually have a grab hook (link) mounted on mine and use it to pull small trees. It's nearly impossible to tip the tractor over because it's attached at the axle (and I have weighted tires).
Now I know why the farmer I worked for as a kid always used cotter pins instead of the clips to hold things to the tractors.
   / Swinging drawbar #18
Thanks guys, had not run into one of those before. My Yanmar has a drawbar, but it doesn't swing.
   / Swinging drawbar
Actually, I'll bet it does swing.... it's probably very similar to the one on my Cub. It's (was /forums/images/graemlins/frown.gif) a bar about 20 inches long with three holes (storage, operating, storage w/ Mid-mount mower).
According to my operating manual, the operating position is fully extended, allowing the bar to swing side-to-side.
   / Swinging drawbar #20
No..........the drawbar on my Yanmar does not swing. It has 2 adjustments..........all the way in and 3-4 inches out from that.
At least on mine /forums/images/graemlins/grin.gif
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2019 Deere 35G (A53317)
2019 Deere 35G...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
