Swinging back blade on Boxblade
/ Swinging back blade on Boxblade #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Would someone mind explaining the theory behind a swinging rear blade on a Boxblade? The Ford 3000 I just bought came with a Boxblade that has a swinging rear blade. The 3 box blades I have used in the past were fixed. Wondering if this something desirable or should I weld it /forums/images/graemlins/wink.gif
/ Swinging back blade on Boxblade #2
On a fix blade BB, dirt will build up between the front and rear blade, which will cause the blade to rise a little off the ground. A swinging rear blade will let the dirt out so this won't happen.
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
RoadTec RP190 (A63689)
36in AIM Tooth Excavator Bucket (A64194)
36in AIM Tooth...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
