Swing cyl. on case 530
/ Swing cyl. on case 530 #1
joebob
Manchester MI.
Case 530CK
Anyone know the procedure to remove/install the swing cyl's on a 530? When the cyl's are disconnected, can other cyl's be operated w/o loosing oil, or do the hoses have to be plugged?
Cheers
Joebob
/ Swing cyl. on case 530 #3
The hoses have to be plugged or the fluid will spray out. I was able to rebuild/reseal both of my 530's swing cylinders without removing them- just unscrew the gland and pull the whole rod assembly out, rebuild and then reinsert them. The boom will need to be positioned most of the way over toward the opposite side from the one you are rebuilding.
Many thanks for your reply, Eric, thats just what I needed to know.
Cheers
Joebob
/ Swing cyl. on case 530 #5
I have a 580B, did same as above except I set the boom centered (bucket on ground, of course) and then pulled the pins that attach cylinder rods to the boom swivel so each cylinder body could pivot away from the boom - then used a comealong to pull rods (a pickup with a good hitch helps)
It's good to have a way to catch fluid - as you pull the rods out you will understand :=)
Not sure about 530's, probably the same - mine have 4 holes in the face of the gland nut AND a setscrew that must come out first.
All the commercially available spanner wrenches I saw were overpriced and too wimpy to get an older gland nut to move, so I took some 3/8" by 4" flat steel, cut a hole (hole saw, drill press) just slightly larger than the rod diameter for each cylinder, then cut thru the center of the hole and drilled 1/4" holes to match the spacing of two opposing holes in the face of the gland -
I then (temporarily) installed bolts with nuts both sides of each hole, long enough to weld nuts on ONE side (wire machine is best for this, or TIG) - Then unscrew the temp bolt and other nut, and thread a grade 8 bolt into the welded nut from the OPPOSITE side and use either a sawzall or zip disk and cut the head off this bolt, leaving ONLY enough UNTHREADED bolt sticking out of the (non-nut) side of the steel to just bottom out in the holes in the face of the gland nut.
For a "cheater" bar, I bought a re-bar bender (home depot) which is essentially a 3 foot long piece of pipe with a flat piece on the end, and 3 3/4" diameter pins welded into the flat part - this is normally used to place the pins over a piece of re-bar and bend it on site.
I then drilled 3 3/4" holes in the flat plate (the one with the nuts welded on) matching the 3 pins on the rebar bender, and used that to get a 3 foot handle on my "spanner" - I know it sounds like a lot of work, but some of my cylinders were unbelievably stubborn coming apart.
If you have a welder but do NOT have the capability of drilling large holes, you could just weld a 3 foot piece of 1-1/2" square tube to the plate with the "pins" I first described.
I may have a couple of pix somewhere, if you're interested let me know and I'll look. Another reason to NOT remove the cylinder bodies - if your cylinders are anywhere near as bitchy as mine were, you'll want the body ANCHORED to something while you swear at it (oops, I meant WORK on it :=)
Also, my local parts rapist wanted about $60 per kit for most of my cylinders, I found them here
Equipment Parts Source, Inc Catalog
for $24 each. They don't list parts for the 530, but call them - some of the Case stuff overlaps, and the 580B's had at least two different versions, one of which might match yours... Steve
Steve;
Many thanks for the info. Also check out epinions.com/case530 (or580). I saw swing cyl. seal kit for less than $8.
/ Swing cyl. on case 530 #7
Here is a link to a page that should be very helpful to you working on your 530.
Case 530CK - Tractor Specs
I found it several years ago, quite by accident when looking for parts for my 310B.
Not only does it have the specs, but in the menu on the left, full service manual by sections, including tractor, loader, and backhoe, and complete parts manual for all also.
I try to post this link everytime I see someone with a 530. Hope it comes in handy..!!
17601CFL (A59228)
17601CFL (A59228)
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
2022 EZ-GO ELITE...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
EZ Trail 3400 (A63688)
