Sweeper
/ Sweeper #1
hwp
Platinum Member
St. Catharines, Ontario, CANADA
Kubota F2400
I recently purchased a well-used sweeper which I rebuilt and is now ready to use. My main use will be light snow removal. It was in good mechanical condition but needed a fair bit of TLC.
/ Sweeper
One problem I had was that the frame of the sweeper could drop down far enough for the angling cylinder and post on the swivel plate to drag on the ground. I attached a piece of angle to the swivel plate and then mounted a pair of anti-scalp rollers from a mower deck on swivels to keep the mounting frame off the ground. So far it seems to work.
/ Sweeper #3
I guess you have pretty dry snow up there, down here that wouldn't work. Our snow is wet and very heavy.
/ Sweeper #4
I have a walk behind sweeper and use it when there is just a dusting or after I plow to get the balance off before it turns to ice. Works well, but sometimes it can be slow going with only a 30" sweeper....
/ Sweeper #5
Howard,
That sweeper makes a pretty good de-thatcher also. My neighbor uses something just like that and you wouldn't believe the crap that he gets out of his lawn by sweeping it. Give it a shot and see if it works for you.
Murph
/ Sweeper
Hi Murph:
I had an old walnut tree on the edge of my property die this summer and I finally got around to cutting it down. I asked my neighbour if I could fall it on his property and he said that was OK with him. There was a tremendous amount of small twigs and branches left after we cleaned up the stuff we could burn as firewood and use as kindling. So I decided to try using the sweeper to clean up the mess. It did a great job of putting the debris into a windrow and it dethatched his yard at the same time. I didn't use it to dethatch my lawns this year but I will in the future. I also used it to spread sand on part of my lawn. I first aerated the lawn and then spread sand over to help break up the clay. The sand was too wet to flow through my salt spreader so I spread it by hand. Then I used the sweeper to even out the sand. It apears to have gone into the holes from the aeration which is what I wanted. /forums/images/graemlins/smile.gif It will soon be time to put the cab on the tractor and mount the snowblower and salt spreader to deal with winter snows.
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
John Deere 328E (A63688)
John Deere 328E...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
4022CFL (A59228)
4022CFL (A59228)
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
