Sweating Copper/Brass
/ Sweating Copper/Brass #21
Jim, just get screw ends for the copper. Sweat them on and screw them into the valve. If you have a union, it is easy, if not use a copper coupling. Propane torches are normally pretty marginal on heat for sweating copper. Guess you cleaned them and used flux.
Wen,
You're the second or third person that said that propane torches are marginal on copper, so I must be one heck of an amateur solderer because I soldered 15-20 spots on 1" copper with no problem at all! /w3tcompact/icons/smile.gif
The problem is the brass valve and I think that Gordon hit the nail on the head, big heat sink and not enough heat. Should have told the guy at the plumbing store that I was an amateur and that I was using propane to get some pointers. Already bought the brass valve with sweat ends.
Might take it to my co-worker, the welding teacher and have him sweat in two pieces of one inch copper, then I can sweat those in place with the propane torch.
Thanks everyone for all of the responses, I knew that the knowledge here would be helpful! /w3tcompact/icons/cool.gif
JimBinMI
We boys and our toys!
/ Sweating Copper/Brass #23
Jim,
If all else fails you can just heat the pool water with the propane torch directly... /w3tcompact/icons/smile.gif
bcarter,
No thanks, that would cost more money than using the solar panels! /w3tcompact/icons/laugh.gif
JimBinMI
INSPECTION (A65583)
INSPECTION (A65583)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2022 EZ-GO ELITE...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
2023 JCB S3246E...
