Sweating Copper/Brass
/ Sweating Copper/Brass #21
Jim, just get screw ends for the copper. Sweat them on and screw them into the valve. If you have a union, it is easy, if not use a copper coupling. Propane torches are normally pretty marginal on heat for sweating copper. Guess you cleaned them and used flux.
Wen,
You're the second or third person that said that propane torches are marginal on copper, so I must be one heck of an amateur solderer because I soldered 15-20 spots on 1" copper with no problem at all! /w3tcompact/icons/smile.gif
The problem is the brass valve and I think that Gordon hit the nail on the head, big heat sink and not enough heat. Should have told the guy at the plumbing store that I was an amateur and that I was using propane to get some pointers. Already bought the brass valve with sweat ends.
Might take it to my co-worker, the welding teacher and have him sweat in two pieces of one inch copper, then I can sweat those in place with the propane torch.
Thanks everyone for all of the responses, I knew that the knowledge here would be helpful! /w3tcompact/icons/cool.gif
JimBinMI
We boys and our toys!
/ Sweating Copper/Brass #23
Jim,
If all else fails you can just heat the pool water with the propane torch directly... /w3tcompact/icons/smile.gif
bcarter,
No thanks, that would cost more money than using the solar panels! /w3tcompact/icons/laugh.gif
JimBinMI
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64277)
KNOW BEFORE YOU...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
Peterson Horizontal Grinder (A62613)
Peterson...
2004 GMC Sierra 2500 (A66408)
2004 GMC Sierra...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
