swashplate sensor problems
/ swashplate sensor problems #1
swein
Maryland
toolcat 5600
Have any of you toolcat owners had problems with the swashplate sensor a 50-20 error code. Loose power to all wheels and when restarted becomes operable until the error code comes on again. If so, what did you do about it and what did it cost? swein
/ swashplate sensor problems #2
There is no way to override the system to operate without it. It requires signal from both swashplate sensors to keep front & rear axle speeds close to same. Replacing the sensor is not difficult, more than likely it is getting access to it that is time consuming. Not sure how accessable they are on the Toolcat but in the skidloader 1 is easy to get to, the other requires taking pump mount loose and jacking it up and more times than not this is the sensor that goes bad.
/ swashplate sensor problems #3
i have a Bobcat A300 its right swash plate sensor creat a problem (swash plate not in neutral).how i replace that sensor?
/ swashplate sensor problems #5
Sensors are on bottom side of hydrostat, opposite the electronic controller solenoids.
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2017 ISUZU NRR 4X2 S/A STAKE BODY TRUCK (A67148)
2017 ISUZU NRR 4X2...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2022 EZ-GO ELITE...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
