Swapt Trailer for Trailer
/ Swapt Trailer for Trailer #1
deepNdirt
Veteran Member
Nth East Ga, USA
yanmar YM-1700
I had the perfect size trailer for my CUT tractor, Trailer being size 5' x 13.6 dove tail with hinged ramps dual axle, brakes on 1 axle, 14" bias tires. this medium to heavy duty trailer towed great,
It's original owner had been using it to haul his Ditch-Witch trencher & spool of cable,
I've been using this trailer for a couple years to transport my compact tractor. Although this size trailer only haul the tractor with its FEL along with only 1 implement, I have found times that I need to have another tool but no space to haul it,:cool:
So! Decided to seek out a trade for a larger trailer, Perhaps someone would trade even-steven? Last week this such person contact me and said he would trade and explained that he no longer has a truck large enough to pull his 6.5 x 16 ft. trailer and would be glad to trade down to my smaller trailer.
He also advised me that his trailer is just like mine only larger, This had me very interested so I decided to go take a look, His trailer was sitting in tall weeds and looked good from the tops side and tires were good with no dry rotting, Basically all I could see is it would need paint and some boards replaced........ turns out this would be the least of my problems:cool:
I go ahead and make the trade for a 6.5 x 16
I realized there were going to be a few trade offs in features, My trailer had dovetail with ramps ... this 16 ft'r did not have ramps or dovetail, my trailer had 1 axle brakes... this other trailer had no brakes at all, My trailer had heavy duty diamond fenders... this other one had thin cheap metal stamped fenders, my trailer had all good wood floor boards,... his would need 4 boards replaced... I was willing to make the trade to gain a much needed and larger trailer,
after getting the trailer home I could better inspect it, I didn't like what I found, The tongue had been replaced and not a very good job done I might add,:mad: I called him back on this and he act as though he had no knowledge of this and advised me he never had any trouble with it this way, but all he had ever hauled with it was firewood logs,
Apparently the tongue had been bent at some point and time, bad enough to needing cut off and replaced, the material used was 3x3 angle iron, when looking back under the trailer I could see it used to have 4x4 angle iron, I wound up re-welding the tongue from the tops side and bottom side, and welding a diagonal pc. from top rail to the tongue to try and reinforce it for now, Later i will weld onto the tongue some 4" channel,
I then moved to the rear of the trailer and cut at the next back cross-member in order to lower and build a dovetail into the trailer making it much easier to load and unload things,
I primed and re-painted it although I will now need to get electric brakes for at least one axle's, even though I had to do much work to it I now have the size trailer I need to haul necessary implements for any job, although thinking back now:eek: I think I could have rather sold my trailer and simply purchased another larger one for less than what time and money I'm having to spend to have this one converted the way I need it,:cool:
My story is to let you folks be aware that what you first think might be a good trade can wind up you getting the bad end of the deal,
This person i traded with now has a perfect trailer that he can simply go use,
I had to spend the better part of 4 days getting this other one ready to use,
I guess I'm not too old to learn new lessons:D
As you can see in the pictures I now have much more room for my extra tools :thumbsup:
actually since taking this picture I have fitted my Box scrape onto the trailer as well,
/ Swapt Trailer for Trailer #2
Well I guess you made it work. but I wouldn't expect to find a good trade in equipment trailers. like you said sell yours and get what you need.
JB.
/ Swapt Trailer for Trailer #3
If you are happy that is all that matters. I have found 9 times out of 10 used trailers are not a good deal in the long run. I have been money ahead just selling mine and buying new when needed.
Case in point. My neighbor bough a 16' trailer. Needed new bearings, new paint, new boards, new wiring, and new tires. All said and done they have nearly $2000 in it. I can buy them new all day long for $1600 around here.
Chris
Another thing you folks should look for when buying a trailer, Is!
( D-Ring Hooks) I didn't realize this 16 ft'r had none until attempting to strap down the tractor, No D-rings:mad: Heck even my smaller trailer had 5- D-ring hooks to strap things down with,:cool: so I guess I'll be having purchase some of these as well @ 12.00 each, plus cost of weld,
/ Swapt Trailer for Trailer #5
Buy a 10' stick of 1/2" re-barb and cut it in 10" lengths, 12 of them. Now weld them in at 45 deg angles between the frame and the vertical uprights for the rail. Gives you lots of options to secure stuff and does not cost a arm and a leg.
I have done this on numerous customers trailers. On my 18' trailer I have theses on each upright. Just drill a 1/2" hole and put them in. No welding. I got mine on EBAY, 10 for $30 shipped to my home.
Chris
/ Swapt Trailer for Trailer #6
I just use the stake pockets, drop the chain thru and bring the hook up and grab the top.
20ft trailer has plenty of pockets, it has the rail as well not sure if that's as safe to use
JB
Hey! Diamandpilot.. great Idea using the shackle rings, Thats exactly what I'll use:thumbsup: and if I decide to ever trade again, I can simply remove them :D
and -JB4310- it has also accrued to me after looking at your trailer that I need to get some DOT reflective Tape, oh well, the money I saved on not buying D-rings I can use to buy the tape ;)
BTW the 18 ft trailer I had a few years back had the stake pockets as well, and i could do as you mentioned,
There is no comparison between the 18 ft. trailer i had and this wimpy 16 ft'r, when I quit buying old cars I had no more use for such a large trailer while having a small tractor, This is when I started trading around for a better suited size for my tractor, Funny though now I have got back up to close the size of the 18 ftr I had in the beginning, but only half the quality of trailer,:eek:
/ Swapt Trailer for Trailer #8
Conspicuity tape is the fancy term. Spell check doesn't recognize the word though.
We had the manufacturer in the next town, Reflexite they may of even had the patent, not sure. But everyone around here was able to get it for free at one time from acquaintances who worked there.
Reflective products - lighting optics, optical engineers, polymer processing - Reflexite
Haven't seen any lately so I think they cracked down on the freebies.
They whack you pretty good for that stuff, not cheap.
JB.
/ Swapt Trailer for Trailer #10
25% off today only at HF, any one item!
/ Swapt Trailer for Trailer #11
I wonder if the o/p deepNdirt wishes he had taken the four days of repair time and extended his original trailer? I know he posted to give us all a heads up, which was appreciated, and mentioned that he should have sold it and bought new. It would have been a lot of work to extend his original, but not four days worth, unless he gets sidetracked a lot like I do. Probably would require repositioning of the axles but maybe he could get lucky like I did on my last extend job, which allowed me to only move the front axle to the rear, making spring hanger movement a lot easier. I left the front hanger just in case the new owner wanted/needed a third axle since he was hauling 2 full sized vehicles on it.
Just a thought...
David from Jax
/ Swapt Trailer for Trailer #12
Chris
ebay is great for picking up shackles. I've got a wide range of them, from 1/2" all the way up to a 1 1/2" (it was $.99). I use them all over, whether it's tying loads down to a trailer or connecting the ends of a sling wrapped around a tree to protect it. You just never know when you'll need one or two.
Just a thought...
David from Jax
When first getting the smaller trailer it was originally 12' long, I added the 1.5 to the rear giving it the dovetail, this made the trailer almost equally balance over the axles, I could lift the tongue by had with little effort,
the one thing I could not do though is stretch the axles making them wider:D
2 of my implements Disc harrow and pulverizer are over 5 ft. just a Tad to wide to rest on the deck of a 5 ft trailer, resulting in me having to rest them on top of the railing,
thus the main reason in needing a larger & wider trailer
when stating I worked 4 days on this trailer some folks might have taken it literally:eek: I should stand corrected and state that I worked on it 3 to 4 hours each of 4 days,;) although I have been known to drag a project out for several months and sometimes years:D
I suppose I could've held off and awaited to sell my trailer, actually I had many inquiries to buy it outright, selling it wouldn't have been a problem,
I also had many offer in trades with Home built trailers but the axles were rigid and weld directly to the frame, they may have been well built and heavy duty, I just didn't want one with having no springs,
trading for this trailer was kind of a sudden need as I have things I must do with my tractor requiring more tools, travel time and fuel cost to run back 20+ miles to switch out tools just made it none feasible, so when I found what i thought was the perfect trailer I guess I traded in hast:eek: although I am getting it the way I need it:thumbsup:
i only started this post to make aware of a trade gone bad experience, in effort that others might look beyond the obvious when in market to buy or "trade" for a used trailer,:cool:
/ Swapt Trailer for Trailer #14
How do you guys get away without brakes on ALL axles? Around here they tell us to get her rolling on the gravel shoulder then hit the trailer brakes only. They expect to see all of the trailer wheels lock up....
/ Swapt Trailer for Trailer #15
Different places-different laws
State of Washington trailer brake regulations:
Every trailer having a gross weight exceeding 3,000
pounds must be equipped with brakes on all wheels and
capable of being applied from the towing vehicle. Any
trailer whose gross weight is over 3,000 pounds must be
equipped with a device which will automatically apply the
brakes in case of a breakaway.
Trailers with a gross weight of 3,000 pounds or less must
be equipped with brakes if the weight of the trailer(s)
exceeds 40 percent of the weight of the towing vehicle.
Trailers manufactured and assembled prior to July 1,
1965, having a gross weight less than 2,000 pounds
need not be equipped with brakes.
Here in Ga.
The requirement for axle brakes: is when trailer and load exceeding 3,000 lbs
max width: 8 1/2 ft.
Hight : 13 1/2 ft.
55 mph : while towing trailers
I would think that any trailer being built with dual axles has the capabilities to haul more than 3000 lbs. and should have been built with brakes from factory,
Not sure why this trailer I have has no brakes:confused: it is factory built although not super heavy duty built, How would one find out about the axle strength? when the tongue was replaced all the info about weight is gone,
I can see they're not as large round as the ones I had on my 18 ft'r and they were 3500 lb axles,
I think I'm off to the salvage yard to find some axle brakes assemblies;)
/ Swapt Trailer for Trailer #17
Here in Indiana we must have brakes on trailers over 3,000# Does not state how many axles. Most only have them on the rear axles until you get upto 12,000# GVWR then brakes on all axles.
In Kentucky they do not require brakes at all for example.
Chris
/ Swapt Trailer for Trailer #18
In CT both axles have brakes, even on 4 and 5 ton trailers, not sure on lighter trailers. I have a small single axle utility trailer with no brakes.
JB
TAG 32in. Bucket Excavator Attachment (A60352)
TAG 32in. Bucket...
1999 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61568)
1999 Fontaine...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
832726 (A61166)
832726 (A61166)
2017 Dodge Journey SUV (A61569)
2017 Dodge Journey...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
