Swapping tires on a 3320 with 72" MMM
   / Swapping tires on a 3320 with 72" MMM #1
jbbankshot
John Deere 3320
I was considering swapping my tires to get a wider stance but after looking at it with the 72" MMM, I think the tires will hit the wheels on the deck. Has anyone tried this yet?
   / Swapping tires on a 3320 with 72" MMM #2
Measure the width between the gauge wheels. The owners manual should tell you the overall width of the tractor with the wheels set to wide position. You'd probably need a couple inches on each side for the MMM to flex though on uneven ground.
   / Swapping tires on a 3320 with 72" MMM #3
Did you consider adding wheel spacers rather than different tires to achieve wider width? That is what I did on my 3720 cab tractor with 72" MMM to improve stability.
   / Swapping tires on a 3320 with 72" MMM #4
I have the 3320 72" mower setup. Swaped mine around with no problems. Mower doesn't hit tires at all.
I'm not sure spacers would be any different then swapping the tires. Unless, the spacers are a bit less then the tire swap.
Is there any issues with driving over it to take off or put on the MMM?
JB
   / Swapping tires on a 3320 with 72" MMM #6
I don't think the op means different tires. I think he means switching them from side to side. Therefore, spacers wouldn't help.
   / Swapping tires on a 3320 with 72" MMM #7
JB
Don't swap the front, only the rear tires. Making the rear wider will gain you the most (or all) the difference in stability.
Thanks for the info!
JB
Just a follow up. I tried swapping my front tires and it is to tight to drive. You can not turn without them hitting the deck.
So, no need for anyone else to try! Swapping the back has helped a lot!
JB
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Reading 8'x18' Metal Flat Bed (A50774)
Reading 8'x18'...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
John Deere 3pt 7' Mower (A50121)
John Deere 3pt 7'...
